12-14-2016, 02:03 AM | #1 |
Hollister Road Co.
Re: Roof replacement?
You can use the Bliar but just know it may eat up the cutters fairly quick on the rust. try to trim back to the arrows and its much easier to remove the strip that's left. You can also use a small chisel to bust the seam after you do the welds. Just lay the plasma gun on the drip edge pointing toward the roof panel that's left and drag it around the top
fyi you should use some cutting oil on the Blair tool or the grease stick they have |
12-14-2016, 07:22 AM | #2 |
Nice time to get rid of drip rails
12-14-2016, 09:59 AM | #3 |
That has been discussed. I read some of the threads on this, not sure I'm ready for that skill level. Having to roll metal and do lead work(for the back part of the rail from what I read) seems a bit daunting....not saying no, yet.
12-14-2016, 10:01 AM | #4 | |
12-14-2016, 12:53 PM | #5 |
Make sure you keep removing material until you get to good metal, like it or not you will probably be doing work on the drip rails and maybe inner panel too. I would take the time to address the concealed side of the inner panel with a rust converter, any left will just continue to work away.
12-14-2016, 07:48 PM | #6 | |
Hollister Road Co.
12-15-2016, 11:50 PM | #7 | |
12-16-2016, 11:46 AM | #8 | |
Hollister Road Co.
12-16-2016, 04:26 PM | #9 | |
