08-10-2023, 07:59 AM | #1 |
Active Member
Need assistance identifying 4x4 parts
Hello all, I'm not new to 67-72 pickups, but am new to 4x4's. I recently purchased a 69 4x4 swb and need help Identifying front/rear differential's, Transmission (4-speed w/granny low), and transfer case. Mainly for the purpose of what fluids to put in them. Do I need lsd in the front/rearends. What is the best brand and weight for the transfer case and tranny.
As you can tell I have some cleaning to do, but I am excited. Pic's attached and once I start de-greasing, I can get better pic's of whatever you need. Thx
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. |
08-10-2023, 11:03 AM | #2 |
Re: Need assistance identifying 4x4 parts
Later model chevy 10 bolt front axle---probably converted to disc brake
rear axle is the stock 12 bolt. trans could be either a SM 420 or 465. 465 will have a pto cover on both sides. T-case is a rockwell 221 |
08-10-2023, 04:17 PM | #3 |
Active Member
kwmech;9228718]Later model chevy 10 bolt front axle---probably converted to disc brake
rear axle is the stock 12 bolt. trans could be either a SM 420 or 465. 465 will have a pto cover on both sides. T-case is a rockwell 221[/QUOTE] ****Thanks for the info kwmech. Yes, it does have front disc. Once I degrease, I'm sure I'll find more markings/info.****
08-12-2023, 12:34 AM | #4 |
All about them K’s
Looks like a 465/T225 to me, which it should be for ‘69 as long as nothing has been changed in that dept. A lot can happen in 50+ years.
As for fluids, 80w90 dinosaur gear oil in everything. I use the Napa brand because I get discount from work. Whatever brand you choose will likely be great, they really aren’t that picky. I don’t recommend synthetic though. You won’t need Posi additives unless you’ve got a posi. When you pull the covers (highly unlikely the front has one from the factory) you’ll be able to tell what you’ve got. The rear axle has a decent chance of being original to the truck I would say.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 08-12-2023 at 12:41 AM. |
08-12-2023, 01:09 PM | #5 |
Your steering shock is upside down at the diff by the way
08-12-2023, 01:48 PM | #6 |
Active Member
Thanks for the info. Here are a couple more pics
The Tranny has this same plate on both sides and a number on the bottom. And a direct rear shot or the transfer case
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. Last edited by SWB; 08-12-2023 at 08:48 PM. |
08-14-2023, 03:49 PM | #7 |
Active Member
Thanks, I flipped it over. Makes more sense now.
