02-05-2018, 12:48 PM | #26 |
Re: Measuring for a new driveshaft - does this make sense?
Can you elaborate on that because I'm not quite sure what you mean? They can build a longer one piece or that I can use those driveshafts to make a two piece?
67 C10 "Big Red" |
02-05-2018, 01:03 PM | #27 |
What I'm saying is that they'll build to whatever specifications you give them. They don't know your specific application (although they're very helpful with providing general guidelines) so that puts a lot of responsibility on you to determine the length, diameter, critical speed, etc. of the driveshaft you want.
1970 C-10 "Old Yeller" |
02-17-2018, 05:53 PM | #28 |
Received my driveshaft from Southwest Speed this week. It fit perfect.
The moral of this story, as others have said, is to provide the measurements that THE SHOP requires. They know what they're doing, not you.
02-17-2018, 06:34 PM | #29 |
Josh,
Does the color match the color of the truck? LOL
Smitty '71 Short Fleetside Spring Valley, Ca. |
02-18-2018, 11:16 AM | #30 |
I can't even match my own clothes, let alone my truck.
02-18-2018, 01:56 PM | #31 |
I'm doing the lwb to swb and wanted a one piece shaft. Every driveline I've had done they always say 3/4". My question is, I'm going to do a 4-6 drop which not only changes pinion angle a bunch but makes a difference for length. Has anyone run into this yet?
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
02-18-2018, 08:40 PM | #32 |
hey redrider what length did you end up ordering? did a swb conversion on mine as well and needing a driveshaft still
