Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-11-2018, 11:45 AM   #51
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 1972 Blazer ls swap
What front cross member would you recommend?
I would like a true "Bolt In" without drilling, but can drill if needed.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-11-2018, 03:50 PM   #52
twp1
I have used Pacific Fab and Dirty Dingo and like them both!! Got the disc brake set up installed and fit perfect and went smoother than I expected!!!!!
twp1 is offline   Reply With Quote
Old 02-11-2018, 05:39 PM   #53
nas93
Originally Posted by twp1 View Post
Yesd! Dave Hall with Restore a Muscle car in Lincoln Neb. Bought it and changed a few things and finished the interior! Adding pic's. Also starting the tear down on the blue one.
Looks good , Is that Competition Red paint? you gave us some great ideas. we are Frame off now and building an LS6. Just looking for 3/4 ton running gears we don't think 600hp will keep those 10 bolt axles under it when we are done.
nas93 is offline   Reply With Quote
Old 02-11-2018, 06:23 PM   #54
twp1
Hugger Orange!!!
Old 02-17-2018, 11:36 PM   #55
twp1
Getting closer to taking back to body shop to put body on!!! Tomorrow going to clean and install old emergency cables and i think i am at a stand still until body is back on!!! Should have pic's of firewall and jams Monday!!!
Old 02-18-2018, 01:45 AM   #56
gringoloco
A guy with a truck
gringoloco's Avatar
Woot!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-21-2018, 07:23 PM   #57
twp1
One more step .
Old 02-21-2018, 07:46 PM   #58
KeithT712
KeithT712's Avatar
Subscribed, This is an awesome build! Curious why the 4l60e and not a 4l80e? or was the motor and trans a package deal? (like a vortec max or denali)
1995 GMC K1500 Suburban 6" Pro comp 35x12.50R17
LSXburb -Build- 1990 GMC Suburban 6.0 Lq4 4l80e np205 D60 14FF
1988 GMC suburban 350ci Sm465 D60 14FF 8" 39.5x15R15
1969 Pontiac Lemans 400ci Muncie 4 speed
2009 Pontiac G8 Gxp M6
KeithT712 is offline   Reply With Quote
Old 02-21-2018, 08:03 PM   #59
twp1
Package out of a Cadillac!!
Old 02-23-2018, 03:14 PM   #60
twp1
Got headers in and not sure if my motor mount is to low but had to grind on frame just a little bit!
Old 02-24-2018, 03:56 PM   #61
CJM72
Looks great! And very familiar? What kind of clearance do you have between the front pumpkin and the Dirty Dingo cross member? I only have a couple of inches and I'm concerned about clearance. I only have an add-a-leaf in the front and 2" blocks out back, but I don't really want to go much higher. Might eventually do a real 2-3" spring lift and I've been thinking about cutting and welding in a plate to the bottom of the cross member to get another 1" of clearance.
CJM72 is offline   Reply With Quote
Old 02-24-2018, 05:05 PM   #62
twp1
ITS NOT A LOT OF ROOM! I AM THINKING THE SAME ABOUT THE 2" LIFT!! Going to wait till i get the body back on to decide!
Old 02-24-2018, 05:49 PM   #63
Blazerowner
Blazerowner's Avatar
I’m doing a similar swap but with a 4l80. Do you know the thickness of your adapter to the np205 and did you move the engine forward and keep the stock position for the tcase? How much space do you have between the core support and the accessories on the engine?
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is online now   Reply With Quote
Old 02-24-2018, 06:24 PM   #64
twp1
Yes I used the stock transfer case location and I believe it moved the engine forward some not sure on how much! Added some pic's. Have about 9" between the pulley and the core support.
Old 03-02-2018, 09:54 PM   #65
twp1
Ordered emergency brake cables from Inline(got them 5" longer just in case i lift it). They fit perfect!!!
Old 03-07-2018, 12:49 AM   #66
twp1
May sell this blazer before it is done to Dave Hall at restore a muscle car like I did my last one!!! Not sure yet!!! I will get more pic's!!!!
Old 03-07-2018, 12:43 PM   #67
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Daves a good guy... He will make it one of a kind...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 03-07-2018, 05:32 PM   #68
twp1
Yes! He bought my Orange One and is his daily driver!
Old 03-07-2018, 08:06 PM   #69
Rickenbach
Lets build the next one with an L86/8L90, and I wont be able to say no.
Rickenbach is offline   Reply With Quote
Old 03-08-2018, 08:44 AM   #70
twp1
Might Happen!
Old 03-13-2018, 08:01 AM   #71
twp1
Still going!
Old 03-13-2018, 11:33 AM   #72
CK5
CK5's Avatar
Nice build! I may have missed it, are you using the AA kit between the trans and tcase, what do you think of it? Looks like it adds about an inch to the length of the drivetrain?
CK5.com
1972 Blazer Build
CK5 is offline   Reply With Quote
Old 03-13-2018, 01:35 PM   #73
twp1
Like it and yes it does look like it adds to length.
Old 04-09-2018, 11:58 PM   #74
Hinz28
Hinz28's Avatar
Awesome build! The orange one is nice! I know Dave and the guys at RMC pretty well. Was super jealous when they first got it. Not many nice ones like that in Nebraska.
1970 Chevrolet C10 SWB 6.0 LSx
1971 Chevrolet K10/30 5.3 LSx
1972 K5 Blazer 8 lug LSX
Hinz28 is offline   Reply With Quote
Old 04-14-2018, 02:31 PM   #75
twp1
He is supposed to get this one when i get the paint on it!
