11-27-2010, 04:31 AM | #1 |
Tire and wheel size suggestion
I'm trying to decide what size of rims and tires to get for my truck. It currently has 15" rim with 35" tires. I want to go a bit narrower and not as tall than what is currently on it. I'm thinking about 33" with 16" M/T classic II rims.
Also plan on reducing the lift and cutting down the rear lifting block, it is way too tall. Any suggestions on brand/model of tires, tire sizes and rim backspacing? Thanks
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
11-27-2010, 05:39 AM | #2 |
Re: Tire and wheel size suggestion
I have always thought the M/T Classic IIs looked real good. As far as tire suggestions...well, I'm fairly partial to Toyo rubber (if someone else is buying) or old stand-bys like Groundhawgs.
11-27-2010, 11:17 AM | #3 |
20' Daredevil (Ret)
Beautiful truck, and I think those wheels would be a good choice, clean & classy without the fake rivets & bling that some wheels have. If you won't be doing much actual off-roading with such a nice truck, tire choice boils down to what looks good to you. For all-around use on a 4x4, I like BFG All-Terrain T/A KO. They list three different sizes in 33" tall range (285/75, 295/75, and 305/70).
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-28-2010, 06:29 AM | #4 |
Thanks everyone for the info.
Any suggestions on how much backspacing?
11-28-2010, 09:13 AM | #5 |
Nice truck! With 16" wheels and wanting narrower I's say give 255/85s a look.They are about an inch narrower than 285/75s and about an inch taller.They are about as close as you can come to the traditional 9.00-16s which is what the WWII omnidirectional military rubber was.Goodyear made an Extra Traction and Coop made the Grip Spur,among others.Maxxis makes a mudder-type and BFG makes them,too.Not sure if in both M/Ts and A/Ts.If you want a bit more beef,the 285/75s are the same proportions and a scale down from 12.50/35s.In 15" BFG makes 10.50/33s and should be mounted on 8" rims,the same for those 16" sizes.But,they will work on stock width as well.
11-28-2010, 12:27 PM | #6 |
With the 255/85 16, what width of rim would I need?
11-28-2010, 02:33 PM | #7 |
20' Daredevil (Ret)
TireRack lists only one tire in that size -- BFG Mud Terrain. They show rim size from 6.5" to 8", with a measured (for their specs) 7" rim width. I would assume 7" is also the preferred width.
11-28-2010, 04:33 PM | #8 |
They work fine on stock steel wheels.I agree that 7" is probably ideal and 8 would work fine.
11-28-2010, 07:17 PM | #9 |
11-28-2010, 11:30 PM | #10 |
I have thought about aluminum slots. Anyone have suggestions on who still makes them?
I have also looked at these ones.
11-29-2010, 03:04 AM | #11 |
The M/T's or the ones in your last picture are the only wheel mfgs that even come close to the alum slots..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-29-2010, 02:23 PM | #12 |
Lakeroadster, what is the outside diameter of your spare? I am looking for one of those fenders for when I move my fuel tank and I was wondering what is the maximum tire diameter it will clear.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-29-2010, 03:29 PM | #13 |
John, thank you for the link and the explanation. I never even knew the long and short box fenders were different. And I apologize for jacking the thread.
Ray
11-30-2010, 06:25 AM | #14 |
11-30-2010, 08:46 AM | #15 |
12-04-2010, 02:21 AM | #16 |
Thanks for all of the help. How much backspacing? The MT Classic IIs have 4 7/16 or 3 5/8 for a 8" wheel.
12-04-2010, 04:34 AM | #17 |
