Old 07-29-2015, 05:19 PM   #1
1972k10wy
TH350 NP205 Adapter Sleeve Coupler
Looking for some help on my 1972 K10, 350, TH350, NP205 Adapter. I want to get a new bearing and sleeve in the adapter but they seem hard to come by for older style. Can I use a newer style sleeve without the bearing and just have it float on seals? Trying to find another solution if unable to find original style bearing and sleeve.
1972k10wy is offline   Reply With Quote
Old 07-29-2015, 08:27 PM   #2
Orange Crate
Orange Crate's Avatar
Re: TH350 NP205 Adapter Sleeve Coupler
The replacement couplers eliminate the bearing in the adapter (no you don't need it in there). I replaced mine (TH350/NP205) and took the bearing out, put new seals in and has been fine for 5 years. Typically when the trans fluid leaks into the transfer case you need new seals. Here is a picture of my old adapter and the removed bearing. See the link below for a typical new adapter shaft without a land for the bearing.
http://www.cmgearworks.com/transfer-...0r4-automatic/
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 07-30-2015, 12:06 AM   #3
1972k10wy
That is good to hear, I was concerned the adapter bearing setup was required for alignment and sealing. Thanks
Old 01-02-2017, 03:21 PM   #4
robs71k5
K5drive
robs71k5's Avatar
I have this nos coupler never installed. Purchased it on line anticipating the need for it but never did have the need to change it Name:  IMG_1157.jpg
robs71k5 is offline   Reply With Quote
Old 01-02-2017, 03:24 PM   #5
robs71k5
K5drive
robs71k5's Avatar
Np205 350th
Old 01-02-2017, 03:27 PM   #6
robs71k5
K5drive
robs71k5's Avatar
27 splines NOS has been sitting on shelf when I purchased from eBay ten years ago . I paid $65 plus shipping then .will offer same today
Old 01-02-2017, 03:30 PM   #7
robs71k5
K5drive
robs71k5's Avatar
