07-19-2018, 05:19 PM | #1 |
Gas Gauge LSX 77c10
I just completed a 5.3ls swap into my 77 c10. I used GM in tank pump/sending unit from a late 80's GM truck into the original 77 tank. My gas gauge isn't working, it is pegged well past full. The gauge worked prior to the swap.
Is the late 80's sending unit and the 77 gas gauge compatible?
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
07-19-2018, 06:15 PM | #2 |
meowMEOWmeowMEOW
Re: Gas Gauge LSX 77c10
You'd have to lookup what the Ohm range is on them. If the resistance range on the sending unit is different than the gauge, it will do weird stuff. 0-30ohm, o-90ohm etc
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-19-2018, 07:03 PM | #3 |
To echo what brew is saying here's a troubleshooting guide that may help....https://www.fillingstation.com/artic...ugetesting.htm
07-21-2018, 04:15 PM | #4 |
What happens to the gauge when you remove the connection to the fuel tank with the key on?
07-23-2018, 12:43 PM | #5 | |
BMW & ASE Master Certified
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
