04-27-2020, 06:24 PM | #1 |
landarts
WTB center tie rod for K20
I have a 68 K20 that has a center tie rod that has been bent. Just checking to see if anyone might have one for sale. See picture of the existing bent tie rod.
71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 69 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
09-21-2020, 10:51 AM | #2 |
landarts
Re: WTB center tie rod for K20
Here is another picture of what I am looking for.
09-21-2020, 05:41 PM | #3 |
Guest
Posts: n/a
Saw this one the other day. Don't know if it's right for you.
https://67-72chevytrucks.com/vboard/...d.php?t=807030 |
09-21-2020, 05:45 PM | #4 |
Guest
Posts: n/a
Napa lists one too.. Don't know about availability.
https://www.napaonline.com/en/search...rtTypeName=Tie Rod Adjusting Sleeve - Front&keywordInput=tie rod&scene=partTypesScene1&fullyQualified=true |
09-21-2020, 05:48 PM | #5 | |
09-23-2020, 01:05 PM | #6 |
Off road design could build you one
09-23-2020, 01:13 PM | #7 |
Those are the driest, non leaking closed knuckles I have ever seen
09-23-2020, 04:05 PM | #8 |
landarts
Thanks everyone for the help and suggestions. I am going with one from DIY 4x4. They custom cut them to match your truck for about $85 with the proper threads and it is much larger and stronger diameter. Again thanks!
09-23-2020, 06:02 PM | #9 |
Guest
Posts: n/a
I'd like to see it when you get it. Post a pic on this thread and let's us know what you think of it after you get it. Thanks!
09-23-2020, 07:05 PM | #10 |
landarts
No problem, I will post a picture and a quick review. When I spoke with him over the phone he explained to install the left and right tie rods on to the truck. Then run the jam nut at least half way up the threads on both sides and measure the distance between. That is the length they will cut it to and will be threaded and ready to go.
09-25-2020, 12:07 PM | #11 |
Active Member
Just an FYI for others. Rareparts.com
maybe reselling someone else's? TIE ROD SLEEVE VIEW FULL DETAILS SKU: 27644 Vehicle : 1972 CHEVROLET K20~PICKUP Location : FRONT $220.26 QUANTITY 1
1972 Cheyenne Super SWB 2wd 402 Orange & White 1971 Cheyenne 3/4 4wd Black & White 1972 Cheyenne Super 1/2 LWB 2wd 402 Red & White 1968 Chevelle SS 396 L78 |
