Old 02-13-2018, 11:07 AM   #1
frenchy51
frenchy51's Avatar
Gas overflow problem
Just finished my '74 K5 and she's looking good! My only problem is when I go to fill her with gas, no matter how careful I am it will puke gas out the filler and down the side on my beautiful new paint job...)-;
It will even do it in the middle of fueling kind of like a "burp". Then always at the end. I've tried holding the nozzle rubber firmly to the side and still a problem. Any advice out there? Anyone else have this problem? Thanks
1972 Highlander PAC B 400BB
1974 K5 Blazer-6.0 swap
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 02-13-2018, 11:11 AM   #2
mongocanfly
Re: Gas overflow problem
have you checked the tank fill vent hose
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 02-13-2018, 11:19 AM   #3
geezer#99
geezer#99's Avatar
I’ve always done the ‘crank’!
Crank (rotate) the nozzle handle around until it’s at about 2 o’clock and fill it up.
You even need to do this on a properly vented tank.
Old 02-13-2018, 12:17 PM   #4
frenchy51
frenchy51's Avatar
Good advice guys-I'll try that next fill up. And also check the vent tube....
Old 02-13-2018, 12:40 PM   #5
mongocanfly
make sure your fill tube isn't pinched as well...there was a burb question on the same thing a while back..he changed fill tube and solved his problem
Mongo...aka Greg
Old 02-13-2018, 12:43 PM   #6
mongocanfly
here it is.....http://67-72chevytrucks.com/vboard/s...d.php?t=750047
Mongo...aka Greg
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
