Old 10-18-2020, 01:07 PM   #1
Mikecc6
Reproduction High Hump
I need a high hump cover and firewall piece for 64 c10. The new reproduction pieces show they fit 1960-1962.
Will they fit 1964? They look like they will but I don’t want to buy something that won’t fit.
Mikecc6 is offline   Reply With Quote
Old 10-19-2020, 08:04 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Reproduction High Hump
Don't know which one you are looking at but Slosh Tubz says they fit 60-66
https://www.sloshtubz.net/store/1960...nels-p78791513
AcampoDave is offline   Reply With Quote
Old 10-19-2020, 08:09 PM   #3
Mikecc6
I did look at the Slosh Tubz piece and it does show 60-66.
I was really looking at steel pieces - Key Parts - and they show 60-62. I thought they were the same but don’t want to spend $300 and find out they don’t fit.
Old 10-19-2020, 08:31 PM   #4
AcampoDave
AcampoDave's Avatar
Maybe you can give them a call. I'm not aware of any changes on the high hump thru the years except the way the gas pedal mounts. 60-62 used bolts and 63-66 had ball studs threaded in the holes but I still dont think that made the threaded mounting bosses any different.
Old 10-20-2020, 06:53 AM   #5
nsb29
nsb29's Avatar
I used an original 60 in my 65
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-20-2020, 04:39 PM   #6
bigmoe
bigmoe's Avatar
I have a high hump someone gave me but are they two piece? because it doesn't go all the way forward.
bigmoe is offline   Reply With Quote
Old 10-20-2020, 05:32 PM   #7
Mikecc6
There are two pieces. Firewall piece and cover
Old 10-30-2020, 03:04 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
It's weird I havnt seen these for 64-66, I wonder why?
http://autobodyspecialt.com/chevy-pi...for-high-hump/
http://autobodyspecialt.com/1960-196...ll-4wd-models/
Old 10-30-2020, 04:47 PM   #9
Ennehazrad
Have you checked LMC? Their high hump firewall piece says it fits 60-66 and costs $90. It’s at the bottom of the page- check it out...
https://www.lmctruck.com/1960-66-che...-filler-panels
https://www.lmctruck.com/1960-66-che...over-high-hump
Ennehazrad is offline   Reply With Quote
Old 10-31-2020, 08:46 PM   #10
PGSigns
PGSigns's Avatar
The one key parts sells should fit the 63 to 66. I sold them both pieces a couple of years ago that I had here for my 65. The plan was to clean them up and laser scan the parts to develop the new parts. The difference I think is the 60 to 62 the hump was bolt in and the later ones were spot welded. I would not hesitate to buy the key parts pieces.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-01-2020, 11:10 AM   #11
Mikecc6
Jimmy
Thank you. That’s the information I was looking for. Mike
