Old 05-28-2007, 02:30 PM   #1
Bowed
OBD-II on these trucks
When did they start using OBD-II on these trucks ? I always thought it was 1996 but someone told me "some " of the trucks had it a couple of years earlier . Thanks.
Bowed is offline   Reply With Quote
Old 05-29-2007, 02:13 AM   #2
wannabelow
Re: OBD-II on these trucks
i have heard that they started doing the 0bd2 in 95 witch was the switch over year and some are obd 2 and some obd but in 96 they were all obd2
wannabelow is offline   Reply With Quote
Old 06-07-2007, 08:59 AM   #3
aggiedave98
I believe it was the law that all '96 and newer cars/trucks in the US had to use obd2. I'm had not heard that there were '95's with it.
aggiedave98 is offline   Reply With Quote
Old 06-07-2007, 01:21 PM   #4
ChevyTech
All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped. In general, this means all 1996 model year cars and light trucks are compliant, even if built in late 1995.
Old 06-07-2007, 03:12 PM   #5
Tink
Tink's Avatar
I believe 95s and some late 94s are OBD 1.5...
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 06-07-2007, 04:29 PM   #6
ChevyTech
I know some pre 1996 cars had the OBD1.5, and it is not easy to find information needed for working on them.
Old 06-08-2007, 01:24 AM   #7
Bowed
I have a 91 heavy 3/4 ton with a rare at the time 4L80 E ( build code's are MT1/MXO which are factory correct for 4L80E ) . What would this truck be , OBD1 or 1.5 ? Is the control for this early "E" transmission the computer or a stand alone module . I'm having trouble finding info on this set up . Thanks .
Old 06-08-2007, 03:11 PM   #8
ChevyTech
1991 would be an OBD1 system.
MXO - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MT1 - TRANSMISSION, AUTO, 4 SPD, THM R2
The RPO codes mean it has a 4 speed automatic transmission with overdrive.
I really doubt it has an electronically shifted 4L80E.
Old 06-09-2007, 01:26 AM   #9
Bowed
Thanks for the reply . I was using " RPO codes.com " and they were saying MT1 is 4L80E . Anyways it has no throttle valve cable with only wires and connectors . Here is what I have . Thanks
