12-10-2011, 08:45 PM | #101 |
Re: Mesquite 1966 C10 - LS3 W/Air Ride
12-10-2011, 10:37 PM | #102 |
Man O Man the lean too is even bigger than my house now I know I'm moving in the shop is assume.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-11-2011, 02:55 PM | #103 |
The boat is very comfortable.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
12-11-2011, 06:47 PM | #104 |
Very, very nice, I'm speechless.
----------------------------------------------- "I wanna be like Dino when I grow up" |
12-11-2011, 08:07 PM | #105 |
Until death do them part thanks again to Jim at Hurst, he made it easy.
12-11-2011, 08:12 PM | #106 |
Wow, very cool!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
12-11-2011, 08:16 PM | #107 |
Thanks guys, trust me I know how blessed I am to have this shop. I'm amazed every day I'm in there, make those 110 deg days this summer putting up red iron worth it.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 12-11-2011 at 08:29 PM. |
12-11-2011, 11:46 PM | #108 |
60-66 Nut
Yes, very nice shop
This is going to be one sweet truck with a LS3 and a 6 speed
12-16-2011, 01:25 AM | #109 |
I am absoultly spechlessly in awl..
12-16-2011, 11:48 AM | #110 |
Wow...
<edit> i would like to do this swap in the future, I want to see where your shifter winds up.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
12-17-2011, 02:57 AM | #111 |
Got the motor mounted, front disc brakes, tested the air ride, was a good night
12-17-2011, 02:59 AM | #112 |
SIIIIIICK!!!!!
Tommy~ The difference between genius and stupidity is that genius has its limits -- Albert Einstein 63 build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=317341 |
12-17-2011, 03:01 AM | #113 | |
Thanks guys, hope to have this thing back on the ground this weekend.
12-17-2011, 03:08 AM | #114 |
And one from the front.
12-17-2011, 10:00 AM | #115 |
This project is what separates the men from boys!
Looks like artwork so far! |
12-17-2011, 12:12 PM | #116 |
Looking great. Cant wait to hear that engine! Last edited by kpc01; 12-17-2011 at 12:40 PM. |
12-17-2011, 12:35 PM | #117 |
Someone's gettin' an x-mas card from their CC company!!
12-18-2011, 12:56 AM | #118 |
Dear Santa...
Just wow, this is an awesome, awesome build. Very well thought out and very quick progress as a bonus! You will have one extremely nice driving truck when it's finished! I haven't seen an official paint scheme yet, so I'll cast my vote for the original yellow/white colors. There's not many trucks around with that color combo so it would be different and stand out, while retaining a bit if the classic/original look. Cant wait to see it finished! Posted via Mobile Device
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-18-2011, 02:03 AM | #119 | |||
Thank you very much fattyarbuckle, this site and the builders here have done as much for this build as I have, thanks again bro
My wife asked me what I wanted for Christmas and my response was Still working on the paint scheme, I really like the gray in the wheels, but yellow always catches your eye Quote:
12-18-2011, 02:18 AM | #120 |
Had to back track some today. One of the front wheels center bore was completely wrong would not even slide onto hub???? Ordered a replacement so won't be back on the ground for another week.
I mounted the engine last night, the original motor mounts were located in the back two holes, the cpp mounts fit perfect in the front two holes and the hole in the cross member, the instructions said nothing about which holes to use, so I used the front two "WRONG". Took the enging back out had to drill a hole in the cross member for the lower bolt then replaced the engine. FYI original oil pan works just fine when mounted in the CORRECT location....yes now I'm the proud owner of a muscle car oil pan that I don't need
12-18-2011, 02:20 AM | #121 |
The engine now located in the correct position, I hope!
12-18-2011, 02:24 AM | #122 |
Notice the string that is strung between the two cab mounting holes. Using this string line I can closely estimate the shifter location in the cab.
12-18-2011, 02:26 AM | #123 |
I think the WD-40 can is close to the most forward shifting location. I think the middle location whould be located close to the exising shifter shown below.
12-18-2011, 09:03 AM | #124 |
Are you keeping the bench seat or switching to buckets ?
12-18-2011, 12:00 PM | #125 |
Very impressive build....
Keep up the great work (and pics) Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
