Old 05-22-2006, 08:39 PM   #1
tkeduk8r
tkeduk8r's Avatar
small block engine decoding help...
have these two small blocks and finally got around to getting the numbers off the pad on front of pass cyl head....first goes like this
16K431089
VO401CMJ
2nd looks like this
1M1011
7VP
any ideas????
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 05-22-2006, 09:07 PM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: small block engine decoding help...
The numbers on those pads are suffix codes I can't remember the exact details but seems to me they were stamped at the factory with a plant code maybe a date code and the last few numbers of the vin. I may be wrong but it's something to that effect. the casting numbers identifying the engine are on the bellhousing flange at the back of the engine on the drivers side. that number will tell you what the engine is as far as model years and hp ratings etc.
Oldtruckfanatic is offline   Reply With Quote
Old 05-23-2006, 12:08 AM   #3
jhow66
jhow66's Avatar
CMJ---1974 350 with T400-- out of a police car-4 bar.carb
CMJ---1980 305 -auto-Camaro
(will need to check casting # on back of block on driver side to see which)
could not finf other one.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-23-2006, 12:14 AM   #4
Oldtruckfanatic
Truck junkie
Hey...I looked everywhere trying to find the suffix decoder but I could only find the casting decoder is that info online somewhere jhow66?
Old 05-23-2006, 11:23 AM   #5
jhow66
jhow66's Avatar
Try here:
http://www.teufert.net/
Old 08-31-2018, 08:22 PM   #6
Adam1971
Sorry to wake up a 12 year old post but 1 was wondering if you ever learned anything about your second code. I have a similar one:
1M0218
7VP
I’ve been looking for months and can’t find info on it.
Adam1971 is offline   Reply With Quote
Old 09-04-2018, 12:43 AM   #7
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
1M should be GM of Mexico, so it is a crate engine.
The 7VP should be the engine suffix. I don't know of a good list for the newer stuff, maybe someone else can help out with that part.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
