08-29-2018, 08:26 PM | #1 |
Mounting bracket for LS3 Connect and Cruise engine compartment fuse box
Need some help. I am at the point of mounting my fuse box on the radiator support. I have had no luck in finding a mounting bracket for the engine compartment fuse/relay box. The searches I have done lead to the conclusion that while one existed for this box (photos below), it is no longer available from GM, etc. Any help would be appreciated.
Thanks, Phil |
08-29-2018, 11:32 PM | #2 |
is a fungineer
Re: Mounting bracket for LS3 Connect and Cruise engine compartment fuse box
A quick Google search says that the bracket was a parts bin item, so you should be able to find something in the junkyard that will work? Apparently it is the same fuse box as trucks and vans.
The trucks supposedly had a plastic bracket that mounted on the fender. Or, a 2000-2005 Astro van: Hope that points you in the right direction.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
08-30-2018, 07:13 AM | #3 | |
08-30-2018, 08:57 AM | #4 |
This where I mounted mine.
OLDIRONRACING |
08-31-2018, 10:14 AM | #5 |
Thanks Oldiron. I did see your mounting in my search of the forum. Looks nice. Did you make that plate for mounting it? That is the general area I would like to mount mine.
Phil |
