Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-27-2017, 02:16 AM   #1
OldCreek
OldCreek's Avatar
Protecting an old paint job
Living at the beach, things rust quickly...
Ive brought a few old trucks home with only minor paint chips only to have those chips start to "rust flower". What was once an aged but smooth paint job would now snag a rag within a year.
What's your best recommendation? A heavy wax job? New synthetic wax/coating applied a couple times a year? Touch up paint over the chips? Or, get busy with new paint job?
Especially, what about a heavily patina'd finish... Paint it quick?!
I've a '84 k10 i just picked up but havent brought it home yet...
Wil
Dang! Should've put in the detailing section!
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
OldCreek is offline   Reply With Quote
Old 09-05-2017, 02:11 PM   #2
jeffahart
jeffahart's Avatar
Re: Protecting an old paint job
I used to live at Ventura County line in Malibu. My place was right on the beach. I had a brand new T Bird Super Coupe. I don't even think it was a year before I started seeing pinpoint size rust dots on the pillars and roof. Not a damn thing I could do, damage done. I would wax for sure, but also cover the vehicle. Don't let the salt laden funk lay on the paint every morning. I had so much stuff ruined living on the beach. It was back in the day of the VCR. Went to show someone a skydiving video I took, Gone, then I found out all my personal videos, offroading, diving , skydiving, all my sport videos.... gone... trashed by the salt air... my list of ruined stuff goes on. Get a maid that can keep everything wiped down everyday... store stuff sealed with moisture absorbers... else; rust, rot and ruin! Keep anything you care about at your pad inland!
Good luck!
j
White K20
jeffahart is offline   Reply With Quote
Old 09-06-2017, 12:00 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
IMO here's how to preserve what ya got as long as possible. I live in the heart of rust country (we literally cheese brined our roads....so you gotta protect).
First its all about cancer prevention:
  • Water isn't the enemy, so long as its got a place to drain. Keep drain holes in doors and rockers free of crap.
  • Wash off any corrosive stuff immediately! (tar, oils, concrete, sap, any petroliate like gas or lighter fluid)
  • Coat your blind surfaces with cavity wax to prevent rusting from the unpainted sides, especially important for old or modified vehicles which have holes and equipment in non-factory locations and may not be weathersealed.
Then its about treatment:
  • If its got full paint coverage and can be waxed, a clean vehicle should get a complete rub on rub off waxing at each season (3-4x a year in year round climates). This protects the good paint from moisture getting under it, UV, and adhesion of icky stuff.
  • In between waxings, when the vehicle gets a light wash or rained on, a spray detailer helps keep things looking good and extends the coverage life of the wax. Not needed for rust, but helps keep the paint healthy but allows for normal use and contact with the environment from daily life. It also helps prevent constant over waxing.
  • Rock chips need to be filled ASAP. Buy a spot sander (pen/brush with an abrasive eraser tip) and scuff the chipped area, then dab in some touchup. Its like a cut on your skin...open wounds can get infection!
Patina is a different discussion IMO. Preserving patina depends on the state of decay, and what kind of paint is aging. I've seen plenty of guys lay 4-5 coats of satin clear right over a patina'd ride, and it looks fine for a while. However unless all the rust has been nuetralized, it will begin to eventually age through the clear again.
I also saw your paint feels rough; before you consider painting or anything like that, consider having a professional paint correction and see if something like clay bar or micro abrasive buffing could save what you have.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
