Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-27-2017, 06:36 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
Body work, what Icing/glaze?
I have a 68' longbox I just cut down to a SWB, I have a bulk of the filler work done with Rage Gold filler. I need to get some Icing or glaze for my top coat before I start spraying High build.
The last time I used it I didnt have great luck and was cussing it for being hard to sand. I dont mind spending more on something that will be easier to work with.
What is the preffered product?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is online now   Reply With Quote
Old 08-27-2017, 06:56 PM   #2
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Re: Body work, what Icing/glaze?
Upol's Dolphin Glaze.
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
http://community.webshots.com/user/sevt_chevelle
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 08-27-2017, 08:17 PM   #3
bigbadchev72
People know me
I just found what was left of the stuff I was talking about. It was the one you suggested. It was like concrete to sand, looking for something a little more friendly to use
Old 08-28-2017, 12:08 AM   #4
Foot Stomper
Foot Stomper's Avatar
Evercoat Metal Glaze. You can even mix a little Rage Gold in if you want a little thicker application.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 08-28-2017, 07:33 PM   #5
MARTINSR
MARTINSR's Avatar
If Evercoat sold tv's I would buy one, big Evercoat fan.
Metal Glaze or Glaze Coat are literally the same product but a different color (had a tech from there tell me that) Metal Glaze comes blue hardener which is way easier to work with than the white hardener with the Glaze Coat.
Here is a "Basics of Basics" on plastic fillers explaining my mentors "one last skim coat" idea that works amazing.http://www.autobodystore.com/ms21.shtml
If you have finished your bondo off nice you don't need it, I personally use it about every time just as a method of applying it, bondo to rough it into shape, one skim coat of polyester putty like Metal Glaze and wham, read for paint ever time. But many bodymen don't use the skim coat at all so it's not a "must" by any means. If you feel that an application of primer would finish it off without asking the primer to "do too much" then you are good. If you would have to ask the primer to fill too much, applying it too heavy or what ever, then you need that skim coat.
But on the same respect if this is a large repair with filler covering the bed side then a coat of polyester primer (again, Evercoat) "Slick Sand" or "Feather fill" could be a good choice being it IS like applying a skim coat of polyester primer, but without all the stripes you put in with a bondo spreader, on a large panel covered with filler or complex panels with bondo them like a tailgate or firewall, polyester primer is THE BOMB!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
