Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-06-2017, 05:41 AM   #1
norwegianc10
Suggestions how to get rid of old sound deadening?
Got some old sound deadening in my doors I want to get out. Seems like some sort of liquid asphalt that has been applied with brush. Approximately 2mm thick.
67 c10 Short Step 350/th400 daily driver
69 Camaro work in progress
norwegianc10 is offline   Reply With Quote
Old 09-17-2017, 11:51 AM   #2
mike16
Re: Suggestions how to get rid of old sound deadening?
a putty knife if its brittle or a wood chisle if its not. I resorted to using a butane torch to warm up undercoating. but inside a door is a tight fit.
mike16 is offline   Reply With Quote
Old 09-18-2017, 12:40 PM   #3
bs46488
Inside of the door makes it tricky.
I had some material that I was able to get off with aircraft stripper and a putty knife, but I had a lot of room to work with.
Good luck.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 09-18-2017, 01:36 PM   #4
MP&C
MP&C's Avatar
If it's not falling off is there any harm in leaving it there? Too much oomph with a putty knife may leave marks, or draw blood. Too much heat may warp it....
Robert
MP&C is online now   Reply With Quote
Old 09-18-2017, 01:36 PM   #5
Jcfcamaro
Jcfcamaro's Avatar
If it's still hanging on real good why not leave it on there?
Jcfcamaro is offline   Reply With Quote
Old 09-19-2017, 12:33 PM   #6
In The Ten Ring
Citrus-based products dissolve asphalt I believe. Give ZEP INC a call and see what they suggest, buy that.
I used to sell for them and they had some hard to beat products.
http://www.zepinc.com/contact/
In The Ten Ring is offline   Reply With Quote
Old 09-19-2017, 07:13 PM   #7
mike16
if a putty knife does not work try the torch deal. It does not ever need to get so hot you must worry about warping it.
one caveate... cheap chit putty knifes, there handle will break apart and you may get it stuck in your palm. OUCH!. if its that bad use a chisle and a torch but not that much heat. kust enough to soften it.
Old 09-21-2017, 06:35 AM   #8
D13
D13's Avatar
Take door off, lay down. plug holes in bottom with clay, fill with paint thinner. Stir until dissolved, drain, repeat.
1987 C10 6.2 oil burner
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
77 1/2 ton 250, 3OTT, and hokey aftermarket AC
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-23-2017, 01:00 AM   #9
norwegianc10
Bottom of door is removed due to rust. Most of it still stick really good, but some of is starting to crack. Thats why I want to remove it, afraid it will let moist in and rust. I have manage to get some of it off, using a flat screwdriver and hammer, and chisel it off. I would really like to clean the door and paint before I weld it back together.
Old 09-24-2017, 08:13 AM   #10
notsolo
notsolo's Avatar
Gunk engine degreaser gel, sometimes works....Kerosene also works, depends on if it really is asphalt, try small area, let soak in to soften.
notsolo is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
