Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 88-98
Closed Thread
Old 06-29-2005, 12:44 AM   #1
ureckme
ureckmefixit2@cox.net
96 Chevy outside door handles
http://67-72chevytrucks.com/vboard/s...d.php?t=161515
I hope this helps. And its hard typ'n w/1 finger other hand got cut at work. Matt
Originally Posted by mcubedntx View Post
I decide today that I would replace my broken 1996 GMC door handle. I am going nuts....anyone have a simple way for getting it back together. I think I bent the little drive arm that attaches to the dorr handle and now I cannot get the travel of the drive arm figured out is there a simpler way????? Thanks
Originally Posted by ureckme View Post
Yes I do. The rod from the latch angles to the inside of the truck when installed right. The bottom of the rod allways gets stuck in the latch if you put it in angled to handle. With handle off put both rods from latch into the latch. Take 2 of the 3 latch bolts out. put key in the lock, install both rods. take #3 bolt from latch ( dont drop latch ) lower latch and turn key and install handle and lift the latch and put bolts back in. Make sure the rod dont come out of the latch. You dont have to take the trim panel off. You can go in thru the vent in the door jam but its tricky. Matt typ'n w/1 finger
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline
Old 06-29-2005, 08:28 PM   #2
krue
Designated A-hole!
krue's Avatar
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
96 S-10 "Pop's Truck"
krue is offline
Closed Thread
Copyright ©2000 - 2020, vBulletin Solutions Inc.
