Old 09-15-2015, 09:24 PM   #1
macdodd
No headlights,,,
Ok,,,I've got all lights except the headlights. I've checked and rechecked the fuses,,all seem to be fine, got a new switch,,,Not, put old one back in,,,,all lights but headlights,,,,HELPPPPPP, Is there somewhere else I should check?
macdodd is offline   Reply With Quote
Old 09-15-2015, 09:28 PM   #2
bill3rail
bill3rail's Avatar
Re: No headlights,,,
Are both headlights blown out? You never know.
You should be following wiring from the headlights back to see where to power is first detected.
bill3rail is offline   Reply With Quote
Old 09-15-2015, 09:40 PM   #3
71swb4x4
71swb4x4's Avatar
Check the dimmer switch. Start by messing with that plug down there and see if anything changes. I highly suspect you will find a bad dimmer switch or an issue with the wiring down there.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-15-2015, 10:12 PM   #4
Jurassic-1
Jurassic-1's Avatar
I would also check the dimmer switch. I would then check the headlamp plugs for power using a test light or meter.
Jurassic-1 is offline   Reply With Quote
Old 09-15-2015, 10:40 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A test lamp or multimeter is your friend..... but if I had to guess, I'd say the dimmer switch (or its connector).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-15-2015, 10:43 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: No headlights,,,
Look at the head lights connectors first. Make sure they haven't come off are broken. If I remember the passenger side feeds off the drivers side. if they are good then check dimmer as mentioned. A test light would be nice to have at least.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-15-2015, 10:52 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Most likely the dimmer switch is the culprit when the headlights are the only thing that doesn't work.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-15-2015, 11:32 PM   #8
davischevy
davischevy's Avatar
Dimmer switch
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-16-2015, 01:33 PM   #9
macdodd
Ok,,,,damn you guys were right on it,,,,dimmer switch. Put a new one in ,,poooof,,,,they work,,,,,one was alittle dimmer that the other,,,so I clean the connector,,,done. Guys,,,thanks again,,,,Bill
