Old 12-04-2018, 01:58 PM   #1
72chevynut
72chevynut's Avatar
Technical help needed on 1984 bucket seat tracks
Hello, I recently purchased a 1984 K30 factory bucket seat truck, bad thing is the bucket seats had been removed and replaced with a bench seat long before I got it. I'm wanting to restore the truck back to the original SPID. So far I have acquired a set of 85 K5 buckets, the correct truck stationary passenger side floor brackets and year correct console. I have not been able to find the correct driver side slider floor brackets so I've been considering modifying the bench seat tracks instead. The technical help I need is the measured height between top of seat tracks and bottom of bucket seat frame, front and rear. I will need to fabricate these two brackets(2) in order to use the bench seat sliders. If someone has a factory set available to measure or a technical design drawing for factory originals, that would be great and much appreciated. Thanks!
Here are some pictures of what I've got so far.
Michael
72chevynut is offline   Reply With Quote
Old 12-05-2018, 08:55 AM   #2
Re: Technical help needed on 1984 bucket seat tracks
That is what I have seen most folks do, use the bench seat brackets and make the stand/mount for the inner track.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 12-05-2018, 10:59 PM   #3
72chevynut
72chevynut's Avatar
Right, I can see why. Hard to find original ones, not many produced. I would like to get a good measurement of the original setup before making the brackets. Thank you for the reply.
Michael
Old 12-14-2018, 03:08 PM   #4
bigblock73
yeller
bigblock73's Avatar
Maybe this will help
http://73-87.com/7387garage/interior...ry_buckets.htm
bigblock73 is offline   Reply With Quote
Old 12-14-2018, 05:27 PM   #5
72chevynut
72chevynut's Avatar
Originally Posted by bigblock73 View Post
Thank you Jeff for the response and link. I had read that article before, unfortunately it doesn't cover the info I need. Since the time I started this thread, I have purchased a set of 86 suburban bucket seat floor brackets. They look similar and have the upper pieces I need to bolt to seat, of course the rear end of brackets need to be bent upward for the standard cab floor. Weird thing is the suburban brackets will bolt to bottom of seat but tracks are wider spaced between themselves than the standard cab floor mounting holes. I guess the blazer bucket seats have different mounting holes or the standard cab buckets seat floor brackets are unique to themselves and mount narrower. I haven't had time yet to try but I should be able to figure something out to make the two sets together, work.
Michael
Old 12-15-2018, 09:22 AM   #6
bhc41051
bhc41051's Avatar
https://www.ebay.com/itm/73-87-Chevy...xUl:rk:14:pf:0
Theses are on eBay not mine.
bhc41051 is offline   Reply With Quote
Old 12-15-2018, 10:28 AM   #7
72chevynut
72chevynut's Avatar
Originally Posted by bhc41051 View Post
Thank you but these parts are already factory welded in my cab floor. They are hard to see in my pics due to them painted white along with the floor. Thanks again for the reply.
Michael
Old 12-15-2018, 11:02 AM   #8
gmachinz
I used 1990 Suburban buckets and console in my ‘86. I sourced 2 complete benchseat brackets from donor 73-87 pickups and used a pair on each bucket seat. I had to drill 2 new holes in the seat bracket frame for each bucket seat so that everything bolted up fine. And the only other mod was shortening the slide liver about 2” because the bench seat ones extend out further than buckets do.
Sorry I dont have any measurements tho-I did this because I didnt want to caveman bend the brackets and have it look goofy...I wanted a factory look.
Specializing in building electrical harnesses and cooling systems
HARNESSWORX
"An army may march great distances without distress, if it marches through country where the enemy is not."
-Sun Tzu: The Art of War
gmachinz is offline   Reply With Quote
Old 12-15-2018, 12:47 PM   #9
72chevynut
72chevynut's Avatar
Originally Posted by gmachinz View Post
I used 1990 Suburban buckets and console in my Ď86. I sourced 2 complete benchseat brackets from donor 73-87 pickups and used a pair on each bucket seat. I had to drill 2 new holes in the seat bracket frame for each bucket seat so that everything bolted up fine. And the only other mod was shortening the slide liver about 2Ē because the bench seat ones extend out further than buckets do.
Okay, I think you have done what Iím needing to do. When you used the bench seat sliders, how did you bolt front of slider to bottom of bucket seat? Did you make a bracket? If you look at my picture with the bench seat sliders mounted to floor, there isnít anything to bolt the bottom of bucket seat to. That is what I need to fabricate and the measured height to make it right.
Michael
Copyright ©2000 - 2019, vBulletin Solutions Inc.
