Old 02-21-2018, 02:06 PM   #1
lukespence
350 swap help
Hey,
I am new to the whole 63 c-10 modding stuff and need some help. Recently bought a 63 chevy with a 283 in it and a 4 speed. We took out the old 283 and dropped in a 350. The 350 was out of a 68. so the engine mounts worked fine. the only problem is that with the engine bolted in there is still a gap between the bell housing and then block. whats up with that?
Thanks Luke
lukespence is offline   Reply With Quote
Old 02-21-2018, 03:01 PM   #2
Clyde65
Clyde65's Avatar
Re: 350 swap help
Is the converter seated properly?
Tried loosening motor mount bolts and perch bolts, then tighten the trans bolts?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-21-2018, 03:40 PM   #3
shortstep60
Re: 350 swap help
Get under your truck and see if you can move the tork converter. If you cant move the tork converter you don't have it all the way back in the trans.
shortstep60 is offline   Reply With Quote
Old 02-21-2018, 03:51 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 350 swap help
If the torque converter is attached to the flywheel then to the crank . . .
As was said already - the torque converter is probably not seated correctly.
Old 02-21-2018, 04:11 PM   #5
geezer#99
geezer#99's Avatar
Re: 350 swap help
Where did you guys read anything about an automatic tranny swap?
I read that he still has the 4 speed.
That needs to be clarified!
Then we can answer his question.
If he still has the 4 speed it’s likely the input shaft isn’t seated into the pilot bearing.
Old 02-21-2018, 04:19 PM   #6
The Rocknrod
Moderator
Re: 350 swap help
It's not my fault, I drink in the morning. Everybody knows that.
Old 02-21-2018, 04:34 PM   #7
geezer#99
geezer#99's Avatar
Re: 350 swap help
But it’s afternoon and evening somewhere too!
I know that quandry.
So much beer, so little time!
Old 02-21-2018, 05:16 PM   #8
The Rocknrod
Moderator
Re: 350 swap help
Doc wont let me have beer anymore I'm too sweet if you know what I mean. But that Jack Daniels Green Label Mmm, Mmm, Mmmmm
Old 02-21-2018, 05:28 PM   #9
lukespence
Re: 350 swap help
yes it is a manual 4 speed. used a clutch alignment tool beforehand. the engine is bolted up to the frame. so it should work. I think I just realized the problem. the flywheel on the engine is from when it had a t5 connected to it. is that the problem is that different.
Old 02-21-2018, 06:37 PM   #10
geezer#99
geezer#99's Avatar
Re: 350 swap help
Shouldn’t matter.
Should slide right in.
You might need to reverse the process.
Bolt the bell to the motor and then slide the tranny in place.
Or hook up your clutch linkage so someone can depress the clutch to release the disc and let the tranny slide in.
Old 02-22-2018, 03:40 PM   #11
61K10
61K10's Avatar
Re: 350 swap help
he said the engine is bolted to the mounts. bellhousing bolted down? Mounts in the forward holes?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-22-2018, 05:47 PM   #12
Wrenchbender Ret
Re: 350 swap help
Some bell housings are for a 10 in. clutch. If you put a flywheel & 11 or 12 in clutch in it won't clear & leaves a gap.
Wrenchbender Ret is offline   Reply With Quote
Old 02-26-2018, 08:19 PM   #13
rvrfoot
Re: 350 swap help
They just read the 350 and thought it was a 350 thans.
rvrfoot is offline   Reply With Quote
1963, 350 sbc, chevy
