09-11-2015, 02:59 PM | #1 |
How does one swap out the rubber gasket on the heater box?
Probably a silly question, but does this gasket just fit on with some sort of caulk? If so, what is best to go back with?
Does it fit into a groove? *Talking about the round gasket on the right here that fits up against the firewall. I have a new gasket from Wes at Classicheatbeat.com Last edited by In The Ten Ring; 09-11-2015 at 03:09 PM. |
09-11-2015, 06:22 PM | #2 |
Re: How does one swap out the rubber gasket on the heater box?
ttt
09-11-2015, 07:54 PM | #3 | ||
"I ain't nobody, dork."
It just seals against the big hole on the firewall. No sealant needed.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
09-11-2015, 08:00 PM | #4 |
Thanks but I think the question was misunderstood. It's clear there wasn't a sealant against the firewall but what makes it stick to the heater box?
09-11-2015, 08:04 PM | #5 |
use a little hi tack just to keep it in place
09-11-2015, 08:04 PM | #6 | ||
I used a little Gasgacinch on mine to just hold it in place.
Gary
09-12-2015, 12:13 AM | #7 |
I picked up some tacky strip stuff from a metal roofing company here locally. It's used where two peices of metal pro panel overlap. I have not used it yet but that's what was recommended by a friend of mine.
09-12-2015, 12:28 AM | #8 |
I like black super weatherstrip adhesive. It just takes a little bit.
09-12-2015, 07:53 AM | #9 |
Yeah, for stuff like that I use weatherstrip adhesive to hold it in place. I used to use hi-tack, but that takes longer to tack-up.
09-12-2015, 09:35 AM | #10 |
Project Junkie! Fishing Poor!!
3M Strip Calk Adhesive is what I use. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-12-2015, 10:34 AM | #11 |
OK, thanks guys.
Now the original is REALLY stuck on there! How do I get that off? |
09-12-2015, 04:20 PM | #12 |
I like the 3m fiber disks that go on the 2 inch angle grinder
09-14-2015, 11:54 AM | #13 |
the aftermarket ones ive seen and used are actually shaped a little different than the original but work just as well. i just got a skinny piece of duct tape on the top to hold the gasket in place and when i got it bolted i removed the tape before tightening the bolts
1967custom |
09-14-2015, 08:04 PM | #14 |
Scrapper 1
One thing about them heater boxes best off to clean them paint them get the gaskets and put a new motor from a AC unit ones instead of the heater only its blows harder and warms up the truck faster.
In my next one i do i will buy the AC controller for my none AC cab I found out that the blower motor switch is easier to replace then the broken arms are on the heater only plus you get to light bulbs to light up your Dash on ether side. I've done one and it worked out grate.Some ask me where is the AC is i told them I wanted the AC controller cus it was better made then the heater one is.Plus i like to set my levers to the way i want them less moving parts.The only thing I have to move is the 3 speed motor switch the Heater one only has a 2 speed. So I'm very happy with my little modified Controller for my heater cab only. And for you guys that have panels or suburbans using the AC controller unit bolts right in place of the heater one you just don't use 1 cable One last thing you might have to add another blower motor rely Last edited by stsalvage; 09-14-2015 at 08:14 PM. |
02-08-2018, 04:38 PM | #15 |
I put my heater box in last night and there's some great tips on this thread. I took a hybrid approach a little hi-tack to hold the gasket in place and some masking tape around the outside. Worked great, the hardest part was getting the tape off once the box was installed.
1970 C-10 "Old Yeller" |
02-08-2018, 08:40 PM | #16 |
I used plumbers putty and it works great. Roll it into a small rope and apply it to the box then after tightening the box just trim off the excess with a knife.
