05-30-2013, 08:50 AM | #1 |
van spindle swap in 68' C10 HELP
so i got a pair of spindles from an 86 G20 van for the disk brake swap in a 67 c10.
i used the correct ball joints from the van and ordered outer tie rod ends the tie rods are larger then the factory C10 ones i then realized they will not fit in my factory adjusting sleeve for the tie rods i ordered g20 inner tie rods and adjusting sleeves the g20 inner is also too big to fit in the steering center link now any advice? do i use the van center link? do i need to change all the steering? am i just going the wrong direction here thanks |
05-30-2013, 12:55 PM | #2 |
Re: van spindle swap in 68' C10 HELP
well i solved the problem
the outer van tie rod is the same a C10 of the same year they make an adapter tie rod sleeve that uses the original 68' c10 outer tie rod as my inner and uses 73-87 C10 stock type outer here is a stolen photo: the part is available from performanceonline.com part #HPAS6570 http://www.performanceonline.com/196...-SLEEVES-PAIR/ |
