02-13-2019, 12:02 AM | #26 |
Roto Reuter thats the name...
Re: Show us where you work on your trucks, Shop tour Thread
A few more.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-13-2019, 12:53 AM | #27 |
Dadgum, that is a nice shop!
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-13-2019, 08:44 AM | #28 |
y’all got more invested in your shops and I got my house LMAO
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
02-13-2019, 10:48 AM | #29 |
Agreed!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-13-2019, 11:12 AM | #30 |
02-13-2019, 11:21 AM | #31 |
Question for the guys with nice floors. In one picture I see someone with what looks like , their grinding the floor surface on an older floor. Are you resealing this yourself or having it done. Watched an episode on Garage rehab where they started moving equipment in the next day. Others say it takes a week to dry. What are the pros and cons of making a nice floor ? Mine is getting stained and dingy.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-13-2019, 11:49 AM | #32 |
Please excuse the mess:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-13-2019, 02:28 PM | #33 | |
02-13-2019, 04:51 PM | #34 |
the results are great. Really brightened up the floor.
02-13-2019, 08:18 PM | #35 |
When we went red on My floor I really just wanted to be able to have something different. 2 years later and it is looking pretty dull compared to when it was new.
02-13-2019, 08:19 PM | #36 |
In the 60ts I would rent a 3 bedroom house so I would have a room for my bike
02-13-2019, 09:05 PM | #37 |
Before I bought the truck. Now i can't get from one end to the other with out tripping over something!
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
02-13-2019, 09:29 PM | #38 |
Dan,
I absolutely love your shop! Nice job.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-14-2019, 12:38 AM | #39 |
rusher - how does the floor finish hold up under traffic. By traffic I mean with moving vehicles with sharp/multiple turning of tires. Also all my "stuff" is on different type of canisters; saws, tool chest, carts, press, etc.
02-14-2019, 12:49 AM | #40 |
Thanks for the kind words Rick. You'll have to stop out some time.
02-14-2019, 01:45 PM | #41 |
My garage is 40 x50 and the front half is for storage parking and the back half if set up with two lifts and all my tool boxes. I don’t have any good pictures of the layout inside but included a few motorcycle shots where you can see a little bit of the lifts and boxes
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
02-14-2019, 02:19 PM | #42 |
Rubber tire marks from hot tires no residue left on floor . Steel castors like on my engine lift when I’m moving or skidding and engine around the steel castors will scratch the floor at times but doesn’t go right through all of coating. Welding it does leave some burn marks I try to cover up area when welding. Cost me about $2500 for material and grinder rentals to do 1600 sq feet of floor
02-14-2019, 03:32 PM | #43 |
Had to get a new roof so I finally got those skylights I always wanted. This shot is lights off in the middle of a rainy day. It took some getting used to. For the first few days I'd walk in and the light would surprise me.
02-15-2019, 01:14 AM | #44 |
Jrusher - appreciate the feedback. 40X 40 is what I have. I really like what you did and when the upgrading of floor makes it on the project list I'd love to talk to you more.
02-15-2019, 09:09 AM | #45 | |
02-15-2019, 09:25 AM | #46 | |
My polished concrete floor is different. That method uses several grits of polishing to close off the pores of the concrete. During the process they use densifiers and chemical resistant materials along with a final top that gets polished into the concrete. This is not a coating. It goes into the concrete, so you don't have to worry about anything chipping off. I can drag around my floor jack or jack stands. I can weld without worry of slag problems. There is minimal maintenance. I only have to wash it down and maybe use a cleaner/degreaser once in a while. The down side of it is that it's not as resistant to oil and chemicals like my other floor. If I spill oil on it I pretty much have to wipe it up right away. Oil will soak in if left on the floor. I love the durability, looks and low maintenance, but hate the fact I have to worry about oil. Grinding and polishing floor. Putting down top cap that gets polished into the floor again. After final polish. Close up of the floor. Final result
02-15-2019, 11:26 AM | #47 |
No problem. I researched a lot of different coatings and this PPG industrial stuff is good stuff . A coatings engineer at work pointed me in the right direction. I’m sure there’s lots other options out there. Main thing I wanted was to brighten the floor up, easy to clean and durability. The floor was in terrible shape before hand
02-16-2019, 09:46 AM | #48 | |
In the past couple weeks I built a storage platform and added some new LED tubes so I have plenty of light working under the lift.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab |
02-16-2019, 12:23 PM | #49 |
