Old 11-30-2019, 06:12 PM   #1
skip99
skip99's Avatar
Welder series four link
I did a ton of research before ordering, and never saw or thought of this, stuff is good quality , welds are beautiful, so , i ordered a welded set...here is the issue, if you are building a truck where the frame is wider at the rear, do not get the tabs on the frame mounts welded, ill explain but the pic should do it, as it is, ill have to angle cut my front frame mounts 1/2.....if the tabs were not welded then it would be simple to square them up,
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 12-03-2019, 01:48 PM   #2
PGSigns
PGSigns's Avatar
Re: Welder series four link
Not sure what your getting at but the bracket you have sitting on the housing looks like a lower bracket. Those holes are usually for the shocks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
