Old 04-18-2018, 09:10 AM   #1
Swatson
3 speed transmission issues
I can shift between 1,2, and 3 but the shifter wont go into reverse. I can get under the truck and physically put it in reverse and then it will work, but then it won't let me shift out of reverse to anything else until I climb under it and move it out again. I had a guy doing some work under the truck, and before It all worked fine. I'm not sure if the linkage parts are hooked up correctly. Anyone have any advice? The linkages are on the side of the transmission.
Swatson is offline   Reply With Quote
Old 04-18-2018, 02:43 PM   #2
T2vigil
T2vigil's Avatar
Re: 3 speed transmission issues
Not sure if this will help but.. Look at the bushings at the top and bottom of the shift rods to see that they are in good condition. Next I would look to see if the shift rod has shifted/slipped from it original location. I have had to do this exact same process.
T2vigil is offline   Reply With Quote
Old 04-18-2018, 02:47 PM   #3
oem4me
Sounds like a rod may have slipped out of adjustment and you are not getting full throw. Assuming they are the correct rods connected to the correct shift arms, make adjustments to rod length up where the rods connect to the column.
Old 04-18-2018, 03:27 PM   #4
Swatson
Do I just play with them a bit, or is there certain position they have to be moved to?
Old 04-18-2018, 04:46 PM   #5
T2vigil
T2vigil's Avatar
The way I do it is put the transmission in neutral. Since you have no trouble with 2/3 make sure to align the shift arm on the column for 1/R with the 2/3. That should get close.
Old 04-19-2018, 02:21 AM   #6
oem4me
As per the General:
Old 04-19-2018, 05:56 AM   #7
Killer Bee
Killer Bee's Avatar
had a three on the tree in a '68 C20 daily driver back in the early 90's..
two things I remember distinctively;
popped out of third under load or freeway speeds so I hooked a bungee cord under the edge of the seat over the shifter when my arm got tired
and every once in a while the shift linkage would get crossed up on the column at the firewall and I would have to go underhood and un-foul it..
follow the manual and verify all your linkage alignments and you'll nail it down..
good luck!
Old 04-23-2018, 08:22 PM   #8
BeardedCowboy87
BeardedCowboy87's Avatar
I have a problem every now and then with mine hanging up in first gear. Mine was originally 3 on the tree but was moved to the floor. Sometimes if I shift too fast out of 1st gear it’ll catch and it won’t go out of 1st. I have to get out and physically move the “rod” to put it into neutral. Then it shifts fine until I forget and shift too fast out of first. I’m not sure if the conversion for the 3 on the tree to the floor is the right one. Is there a company that makes an actual conversion kit for the tree to the floor conversion? I think when mine was moved to the floor was back in the early 90’s.
BeardedCowboy87 is offline   Reply With Quote
Old 04-25-2018, 02:42 PM   #9
Swatson
I got my issue solved temporarily. The two little rod that catches the plates from the shifter handle, was getting snagged and catching and putting it in 2nd gear before falling into the reverse position. Took a piece of L shaped aluminum and rigged it up to pull the 1rst and reverse plate and rod away from 2nd and 3rd. Possibly planning on putting an auto in later this year, so I'll leave it as is for now. Thanks for the help!
