Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-14-2018, 09:51 PM   #1
kmswi
3m super strength molding tape
Can paint prep cleaner be used then rubbing alcohol to clean surfaces before using tape?
kmswi is offline   Reply With Quote
Old 06-14-2018, 11:16 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 3m super strength molding tape
I cleaned mine with just alcohol before using the 3M tape...been 6-7 yrs now and still holding
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-15-2018, 06:05 AM   #3
homemade87
Just rubbing alcohol will do the trick . It leave no residue behind when dry . Be mindful of the rag you use . Some rags will leave contaminates on the surface .
homemade87 is offline   Reply With Quote
Old 06-15-2018, 09:26 AM   #4
StingRay
StingRay's Avatar
Be careful wen you say rubbing alcohol. Typical rubbing alcohol is only 70% and has oil in it. That is a catastrophic problem. You want 99% isopropyl alcohol. Many of the post prep just prior to paint cleaners are little more than Iso and water.
Paint prep cleaner is a generic term but generally yes a wax a grease remover is appropriate prior to any work on a painted surface. How you use these products is as important as what you use. Always use a clean lint free wipe. Wet the wipe, wipe on the cleaner and wipe it off with a dry lint free wipe. Frequently change to a clean area of the wipe and change wipes as necessary. Always wipe on and wipe off in one direction moving any suspended contaminants down the panel. Think of anything on the panel as mud. If you wipe back and forth you smear it around and don't clean it. Wipe it off in a single linear direction and you wipe it away. Sounds picky but it is absolutely critical when cleaning for adhesion of most top coats or adhesives.
VHB tapes like the product you mentioned also require adhesion promoter if use on any of the olefin types of plastics like polypropylene or polyethylene. Know your substrates.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-15-2018, 09:51 AM   #5
MARTINSR
MARTINSR's Avatar
Another thing is depending on where it's at you can use an adhesion promotor. https://www.autobodytoolmart.com/3m-...CABEgLnFvD_BwE
We use this everyday at the shop on the parts that may require a bit more or they were dirty and we need to make sure it's clean.
What mouldings are you using this tape on, a late model truck? Those big mouldings on a late model GM truck can be REALLY tough. Warm them up, be sure they are going on flat and not pulling up on the ends. I have seen WAY too many of the, fail at the ends so I put a dab of window urethane on them at each end.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
