03-17-2019, 09:21 AM | #26 |
Re: C H E V R O L E T hood letter template needed
Randy
How's this project going? If you have had time to work on it, How did the letters turn out?
07-03-2020, 01:43 PM | #27 |
Update? Old thread. Came across this doing research for my letters.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
07-03-2020, 01:54 PM | #28 |
Maybe Randy500 will chime in also about the results.
I have rented this temple out several time now. The temple is currently at a shop where we are working together to make a stick on Decal. I need to call them and see if there is any progress. .
10-31-2023, 08:03 PM | #29 |
Have to give a big shoutout to Dwayne for letting me use the template. Just did the the lining up and drilling today. It was super easy to use and his directions were spot on. Thanks Dwayne !
Thanks,Tom |
10-31-2023, 08:14 PM | #30 |
Thanks Tom
That is One nice truck you are working on. I am glad things went well. I will add that the (Stick on) decal I spent so much time on. The lady that was working with me on this decal sold her business. So It is great to know the temple works.
12-19-2023, 05:24 PM | #31 |
Hello I am looking for a template to add the Chevrolet back to the hood of my 67 can you help? Thanks.
12-19-2023, 08:02 PM | #32 |
milzo
It is currently out on rent. I will return your Pm with details of rental. Thanks
12-19-2023, 09:31 PM | #33 |
12-20-2023, 08:39 AM | #34 |
68 C10 Longbed
https://www.67-72chevytrucks.com/vbo...1&d=1703075496
Fortunately I had the original hood which I replaced so I was able to just use blue painters tape starting exactly on the front edge of the old hood to cover the holes in three long strips, marked the center front edge for alignment, used an AWL to make the holes through the tape and removed the tape in one careful pull and reinstalled tape on the new hood and I had my template. Worked great. |
12-20-2023, 08:42 AM | #35 |
68 C10 Longbed
12-20-2023, 09:06 AM | #36 |
Looks great. This is my 67 that i want to add the letters to the hood. Its sort of a restomod. Full CPP coil over suspension kit, 5.3LS w/4l60E trans. Just changed it to column shift, now need new carpet.
12-20-2023, 01:23 PM | #37 |
68 C10 Longbed
12-20-2023, 05:28 PM | #38 |
i bought a new hood for my 68 due to the amount of rust in the old hood. I am going to make a template from the old truck hood so i can transfer the holes for the letters to the new hood. Once the template is made, transferring the holes for the letters should be straight forward.
12-22-2023, 08:52 PM | #39 |
Just sent you a PM.
Nice looking truck you have there.
01-09-2024, 07:00 PM | #40 |
01-09-2024, 08:16 PM | #41 |
Great News.
Good to hear about the Quality of the letters. This is a good weekend project (If your inside of course) .
