12-14-2018, 03:56 PM | #1 |
Need help, best place to purchase frame crossmember
Greetings, new here, just picked up a 70 c10...been creeping around the forums for a bit.
I have recently taken off what remained of the bed and installed a blazer type gas tank and figured out that my rear cross member is bent...where would you guys recommend finding these reproductions? Thanks in advance |
12-14-2018, 04:06 PM | #2 |
Coordinator of Synchronicity
Re: Need help, best place to purchase frame crossmember
Porterbuilt has a couple of different options in this area, depends on the section you need.
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
12-14-2018, 04:48 PM | #3 |
Thank you sir
12-14-2018, 04:52 PM | #4 |
Go Pack Go!
Become a paid member of the forum and then post a WTB ad in the correct parts section.
12-16-2018, 11:44 PM | #5 |
Sorry, little dense, how do you become a paid member?
12-17-2018, 08:21 AM | #6 |
BlahBlahBlah
Is the metal actually bent, or does the cross member look really crooked? Because one of the cross members looks wrong, but is angled from the factory. I did a quick google search using the search box at the top of the page. Used the 67-72cheytrucks.com button ... rear crossmember. A bunch of threads come up that may help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=467349 |
12-17-2018, 01:42 PM | #7 |
Thanks cg...the crooked one for triangulation is not the one I need...my rear crossmember is bent, guessing PO put a chain to drag it or something else around...would love to put my ua ds on a factory original and swap out, but looks like aftermarket tubular is all I can find.
12-17-2018, 02:17 PM | #8 |
I needed to replace a x-member on my 1 ton. Finding one is really hard for a 1 ton ,....I went to my local steel supply and had them bend one for me. Clamped it in place and used the existing frame holes for drilling
12-17-2018, 02:42 PM | #9 |
You might contact Green's Repair & Restoration in Cameron, TX. (254) 482-0186
They have tons of salvage stuff. Also, the The 1967-1972 Chevrolet & GMC Pickups Parts Board of this site is always good. |
12-17-2018, 02:49 PM | #10 |
Thanks for the Info! Yea, this thought has crossed my mind...have to weigh costs, like the idea of the original look, but I also like the idea of tubular strength...choices.
12-18-2018, 10:56 AM | #11 |
12-18-2018, 11:24 AM | #12 |
Try Early Classic Enterprise I have purchased one from them before. Fits great, looks stock even has the big hole for the light harness. $45.00 in their online catalogue.
12-18-2018, 11:45 AM | #13 |
