01-28-2018, 11:52 AM | #1 |
carb leak rochester 4bbl
just had this carb rebuilt and its leaking where its circled in yellow. what can i use to stop this? epoxy?
01-28-2018, 11:58 AM | #2 |
Re: carb leak rochester 4bbl
Those plugs eventually leak on Rochesters, just clean well and use some JB Weld epoxy. Let it fully dry before letting fuel get on it.
Take Care Troy |
01-28-2018, 12:02 PM | #3 |
thanx, i ran it outta gas and hit it with air to dry. dumb question, whats this for?
01-28-2018, 12:03 PM | #4 |
For a cleaner look use some of this. It’s clear.
It’ll seal a 1/4 inch hole in a gas tank, so it’ll seal your leak. https://www.homedepot.ca/en/home/p.s...000708738.html You did know not to use teflon tape on flare fittings, didn’t you? I see some on your inlet fitting. |
01-28-2018, 12:05 PM | #5 |
01-28-2018, 12:14 PM | #6 |
thank you
02-03-2018, 10:37 AM | #7 | |
