02-19-2018, 09:09 PM | #1 |
Front shock mounting bolt
So am I making this harder than needed? I can’t seem to located anywhere that sells the shock stud that bolts into the frame for the front shock. Somewhere along the line, someone welded, and I use that term loosely, the stud to the frame since the hole was a wollered out. I’m going to remove them, weld up the hole and re-drill, but can’t seem to find the dang stud anywhere
What gives? Thanks Nick |
02-19-2018, 09:36 PM | #2 |
Re: Front shock mounting bolt
Just about every time I by shocks for the front from NAPA the box has a new stud in it. Takes a 15/16'' socket for the nut. 5/8'' hole in the frame
02-19-2018, 09:38 PM | #3 |
I bough a RideTech kit that did not include them with the shocks in the kit. I know they’ve got to be available. Maybe I’ll just venture in to a brink and mortar and see what they have. Thanks
02-19-2018, 09:46 PM | #4 |
I bought Monroe shocks and got net studs with them
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-19-2018, 11:51 PM | #5 |
At the body shop.
Also known as a P-19 pin
" That didnt make it any newer " " Dont antique the equipment " |
02-19-2018, 11:53 PM | #6 |
At the body shop.
02-20-2018, 02:04 AM | #7 |
At the body shop.
Another option: 4wd with factory dual front shocks. The second shock bracket.
02-20-2018, 07:39 AM | #8 |
I welded mine up and put a 1/4" steel washer on the inside of the frame and welded that in. I then replaced the outer bracket with 1/4" steel. (4x4) But could be done with 2x4 too. Then a nice grade 8 bolt and no stud necessary.
They will never waller out again.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 02-20-2018 at 08:01 AM. |
02-20-2018, 04:33 PM | #9 |
Thanks everyone. I did a little digging and was able to find them at Classic Parts (https://goo.gl/cxV6Jm. They just happen to be about 20 mins from me. I had googled and searched for some time. All it took was changing the search to studs and mount and it came up. Sheesh!
Thanks everyone! |
