Old 08-08-2017, 12:30 PM   #1
brown7373
brown7373's Avatar
89 Suburban 3/4 Heavy Towing Pkg.
I have a dried out and brittle and broken vacuum line. It is about 1/64 outside diameter line and goes through the firewall, to the A/C / heater assembly I think. It is a tiny line.
Any ideas on how to splice a new piece in? I have never seen a connector that small. It looks like the small line was glued into the larger rubber connector behind the air cleaner, and that is probably the way it connects to the ventilation system through the firewall under the reel out light on the left.
brown7373 is offline   Reply With Quote
Old 08-09-2017, 01:15 AM   #2
kwmech
Re: 89 Suburban 3/4 Heavy Towing Pkg.
May have to go under the dash and splice a new line out
Old 08-09-2017, 06:39 AM   #3
Edahall
Agree with the above or just replace the line. While towing a very heavy load up a steep pass, the exhaust manifold on my 6BT Cummins got hot enough to melt these little lines off. I patched it so the A/C would work for the rest of the trip but later replaced the line that runs under the dash.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
