Old 12-12-2017, 07:05 PM   #1
groundedc10
Have not stated engine in 3 years???
So I am getting ready to start the engine in my C10 and it ran good before I parked it. Besides the obvious like new fluids and plugs. What else would you recommend I do before starting it? Just don’t want to cause damage to anything. Thanks
groundedc10 is offline   Reply With Quote
Old 12-12-2017, 07:11 PM   #2
truckster
truckster's Avatar
Re: Have not stated engine in 3 years???
When you pull the plugs, put a little penetrating oil in each of the cylinders and turn it over by hand. If you're not afraid of pulling the distributor I would do that and prime the oil system.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-12-2017, 08:45 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Was the cam properly broke in?
Marvel mystery oil or sea foam
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-14-2017, 03:23 AM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
What's been said....and prime the engine for sure. Good way to make a cam go flat is to start a dry engine.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-14-2017, 06:06 PM   #5
Coley
Coley's Avatar
Was fuel stabilizer ever added to the gas tank when it was parked?
If not get several gallons of new fuel and make sure you get that in the tank...ideally to the majority.
What here is what I do when I'm starting up a vehicle that has been in storage and it is definitely in line with what the guys have posted here...particularly, pulling every plug and putting a good shot of oil physically into every cylinder, just make sure you put all the spark plug leads back on the correct cylinder!!
Then I put a socket on the main central (large) alternator bolt in the middle of the pulley and (with a long extension) use that pulley advantage to slowly turn the motor over a couple of turns.
After that, I pull off the coil lead to the distributor so the engine can't fire. Then I use the starter to turn the motor over a few times in short bursts until the oil pressure gauge starts to move up....this doesn't take long, and then you know you are getting oil pressure.
At that point, I re-install the coil lead....and fire it up.
I've never had any bad long term affects on any of the trucks that I've done this with.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 12-14-2017, 10:02 PM   #6
65truckowner
65truckowner's Avatar
Just fire it up and hold it about 3/4 throttle and it will be fine. Just kidding I would pull the plugs and put a little oil in but I think pulling the dist and priming it will a drill is the best way to go.
65truckowner is offline   Reply With Quote
