Old 12-17-2017, 04:39 PM   #1
rustednuts
1954 chevy truck 350 LT1 headers
putting a 1992 350 LT1 in this truck anyone know what headers to use on it?
rustednuts is offline   Reply With Quote
Old 12-17-2017, 06:29 PM   #2
fourspeedwagon
fourspeedwagon's Avatar
Re: 1954 chevy truck 350 LT1 headers
Stock chassis and front suspension? anything else changed we should know to help you--?
1951 GMC 250 Open Express Pickup
1968 Suburban C10
1971 C20 Olive
“People are shocked when they find out I’m not a good electrician”
Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it”
fourspeedwagon is offline   Reply With Quote
Old 12-18-2017, 09:50 AM   #3
youngrodder
youngrodder's Avatar
Yes we really need to know more. I used a modified G-body frame (similar to and S-10) for my 48 and I used some shorty ceramic coated headers by Patriot that I purchased from Summit Racing. They were inexpensive and worked great for my application.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-18-2017, 01:53 PM   #4
morgan71
Aren’t LT1 heads D ports? If so you need the correct headers for those. I’ve got a ZZ4 and bought the stainless DPort block huggers from speedway. I’m running a mustang ii
morgan71 is offline   Reply With Quote
Old 12-21-2017, 02:49 PM   #5
youngrodder
Yes they are D port.
Marc
Old 12-22-2017, 07:12 AM   #6
hogfarm
Headers were a big problem for me.I bought 5 different sets before I found a set that fit.I have a 383 stroker in a 58 chevy truck
hogfarm is offline   Reply With Quote
Old 12-22-2017, 11:52 PM   #7
bosco
bosco's Avatar
Can I ask which ones you ended up going with for your 58? Currently have block huggers and the lower steering joint hits the down tube off the headers collector (had to dent the down tube for clearance, not my first choice).
bosco is offline   Reply With Quote
Old 12-28-2017, 04:43 AM   #8
MiraclePieCo
MiraclePieCo's Avatar
I just watched an episode of Iron Resurrection where they dealt with this exact issue - LS3 in an AD truck. They had to change the headers for clearance but since I don't have an LS I didn't note exactly which headers they used. Easy enough to catch the episode on Velocity channel.
MiraclePieCo is offline   Reply With Quote
