Old 04-08-2017, 11:53 PM   #251
swamp rat
swamp rat's Avatar
Re: Out of the Ditch = The Rebuild Begins ('72 GMC)
Yea you don't need anything but a standard oil pump.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-09-2017, 08:52 AM   #252
SCHRUMGMC
SCHRUMGMC's Avatar
Awesome work man. Loving the progress
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-09-2017, 11:10 PM   #253
sduckworth13
sduckworth13's Avatar
Metal work looks awesome!! If you have more patches to do try out Tabco. Their panels are way better than the Key Parts or Counterparts. They still need a little tweaking, but a way better fit without all the slicing and dicing.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-11-2017, 10:05 AM   #254
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Thanks you'se guys!
Ugh... welder crapped the bed last night. On/off switch no worky. Welder is 8 years old and out of warranty. Part is only 6 bucks. So I need to order it and put the new switch in. I'm only assuming that's what it is as the rocker in the on/off switch feels loose. If this doesn't fix it, I'll have to take it in to the dealer for repair. Which is about a 3 to 4 week turn around time.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-11-2017, 12:17 PM   #255
jjzepplin
jjzepplin's Avatar
Take the switch out and test it?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-11-2017, 04:54 PM   #256
GASoline71
GASoline71's Avatar
Will do that when I get home from work. The internal breaker wasn't tripped either. Hoping that it's just this bad switch.
Gary
Old 04-12-2017, 08:06 PM   #257
Skip44
Skip44's Avatar
Well, was it the switch?
Skip
For those that have fought for it,
Freedom has a flavor the protected
will never know.
Skip44 is offline   Reply With Quote
Old 04-13-2017, 04:29 AM   #258
Xeen
Xeen's Avatar
You are doing some good metalwork, I'm glad to see that you are still at it, keep up the good work!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 04-20-2017, 06:17 PM   #259
GASoline71
GASoline71's Avatar
Skip
I forgot to come back here to tell you guys. Yep... I had tested the switch and it indeed was bad. Got a new one today finally from my Lincoln dealer (Central Welding Supply), installed it and I'm back in business!
Thanks dude! I will eventually conquer this old heap!
Gary
Old 04-21-2017, 08:06 PM   #260
GASoline71
GASoline71's Avatar
Buttoned up the oil pan and pump issue today. So I'm hopeful to have the engine and transmission in the rig soon!
Gary
Old 04-24-2017, 11:14 AM   #261
GASoline71
GASoline71's Avatar
Spent a day and a half removing all of the thick black overspray on the lower half of the firewall from the factory undercoating. What a PITA. Used a heat gun and some soft wooden paint sticks as scrapers. Then after I got most of the thickest stuff off, I used rags soaked in mineral spirits to get the rest off. I used a little Goof-off too, but the mineral spirits worked better. Here are a few pics of the during and after.
This week should be engine and tranny install week! Slow and steady wins the war!
Gary
Old 04-24-2017, 01:08 PM   #262
Coley
Coley's Avatar
Smile Re: Out of the Ditch = The Rebuild Begins ('72 GMC)
Yeah, I have some of that on the lower cab/tunnel area of my truck too.
Was that simply overspray from the factory when they gave a couple of quick sprays from below onto the frame? or was it applied earlier and 'strategically'?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-24-2017, 03:08 PM   #263
67ChevyRedneck
67ChevyRedneck's Avatar
Well, if you ever want to do a perfect factory color match... there's where you take your sample from
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-24-2017, 04:01 PM   #264
GASoline71
GASoline71's Avatar
Coley
Overspray from the poor sap in the pit below the assembly line spraying that slop on from below.
Yup. Funny as that paint doesn't match the paint on the doors and cowl. So this truck was repainted at some point and they tried to match the factory Medium Green.
Gary
Old 04-27-2017, 10:27 AM   #265
GASoline71
GASoline71's Avatar
Well whaddaya know... it still fits!
Had 3 of my good buddies over last night for the reinstall of the 355 and TH350 back into the frame. What a happy day!
Gary
Old 04-28-2017, 10:32 AM   #266
knomadd
knomadd's Avatar
That's awesome! Glad to see more progress.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-28-2017, 12:50 PM   #267
Low Elco
Whoot Whoot!
Low Elco is offline   Reply With Quote
Old 05-09-2017, 09:35 AM   #268
GASoline71
GASoline71's Avatar
Originally Posted by fecklessgadfly View Post
Be sure to update us when you find one. I'm sure several of us are getting ready to do those repairs, and you might save us a lot of hassle.
I ended up ordering a drivers side outer rocker from Wes at Classic Heartbeat yesterday. They are made by Triplus. Looking forward to getting it so I can see the difference.
Gary
Old 05-15-2017, 02:37 PM   #269
GASoline71
GASoline71's Avatar
As promised... here is the skinny on the drivers side outer rocker panel. I received the panel from Wes at Classic Heartbeat lickety split. I did a trial fit and was pleased with how it was lining up. So after a few hammer shots here and there and some slight tweaking to get the front to line up, I had it fit in place with a few sheet metal screws in about a half an hour!
I lined up the fender and the door, but need to get new hinges to set it right before I drill holes for "spot welds" and do the final weld in. I, for the life of me, cannot get the hinge pins out of these rusty old hinges. Even using the biggest BFH I own. So I have new hinges on order from Wes.
Now for the particulars. The outer rocker panel I received from Wes is made by Key Parts/Tri-plus. The other I had was made by Dynacorn. After going back through some threads and doing more research, I found I had the "double sticker" panels that ended up being factory rejects that were put back into circulation. So if you get ANY panels with the double stckers from Dynacorn... avoid them like the plague! I have included some pics of the fitment of the new panel and a couple of the labels from each panel.
It took me 3 days of fab work (probably about 10 to 12 hours) to fit the Dynacorn panel on the passenger side and I'm really not all that happy with it. But it is staying in place for now. So far I have half an hour into the fitment of this new panel from Key Parts/Tri-plus. So... there ya go! Thanks for the recommendation and fast shipping Wes!
Gary
Old 05-15-2017, 02:47 PM   #270
GASoline71
GASoline71's Avatar
Pics of the labels.
Dynacorn = 2 labels
Key Parts/Tri-plus = 1 label
Gary
Old 05-15-2017, 09:29 PM   #271
swamp rat
swamp rat's Avatar
And the double labels are being sold by a number of different places, I won't mention where I got mine but lesson learned.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-15-2017, 10:28 PM   #272
Skip44
Skip44's Avatar
Is there a reason your not telling us where you got the bad parts?
Skip
will never know.
Old 05-16-2017, 03:46 PM   #273
GASoline71
GASoline71's Avatar
I bought mine at Dreamers Rods and Pickups in Everett, WA. Whether they knew about it or not, I don't know. But I will buy stuff from them again if I need it. They are close enough for me to drive there. So I can now check to see if there are double labels on parts. I would also still recommend them for other parts if you live in the North Puget Sound area.
Gary
Old 05-16-2017, 10:14 PM   #274
swamp rat
swamp rat's Avatar
I bought floor pans from Dreamers, Dynacorn, yea not very good stuff.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-18-2017, 07:04 PM   #275
GASoline71
GASoline71's Avatar
So I got after the surface rust on the cab floor. Then sprayed some etching primer on the bare metal on the cab floor today. Next up will be some seam sealer and then a bit more primer. Then some paint. After that I will lay down some Fat Mat.
Gary
