07-27-2017, 08:55 AM | #1 |
C10 doors to Blazer doors
I'm sure this has been done. Has anyone cut down 69-72 C10 doors and made them into Blazer doors. They look the same other then doing away with the top portion of the window frame. Any problems in doing this?
07-27-2017, 09:07 AM | #2 |
Re: C10 doors to Blazer doors
That's how the factory did it, if I'm not mistaken the assembly manual you can buy shows the process.
07-27-2017, 09:14 AM | #3 |
Thank you, this information is helpful!
07-27-2017, 09:34 AM | #4 |
I seem to recall Blazer doors have reinforcement pieces built into them that the truck doors don't have. Someone might confirm this.
07-27-2017, 09:43 AM | #5 |
One of the First
You can use truck doors, but suburban doors will work too.
Updated: Here you go - http://67-72chevytrucks.com/vboard/s...d.php?t=273729
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 07-27-2017 at 04:20 PM. |
07-27-2017, 10:36 AM | #6 |
You are correct they have a reinforcement plate spot welded in at the latch area. Remove them from your current doors before you scrap them I don't know how many sets of those I have sold. There is also a stainless steel plate that is screwed to the doors that the truck door will not have.
07-27-2017, 11:06 AM | #7 |
I'm actually going to do this myself. It is in the assembly manual. there are three cuts to make.. I'm going to a bone yard to get doors this weekend as long as they are in good shape...
07-27-2017, 12:13 PM | #8 | |
67-72 parts collector,…
07-27-2017, 04:25 PM | #9 |
The previous owner trashed the original Blazer doors and put truck doors on so I guess I'm out of luck. I will have to try to fabricate some new parts or look for donor Plates.
Thank you everyone for your replies! |
07-27-2017, 08:22 PM | #10 |
I have made door plates out of bad doors. cut out the area around the latch and roset weld it to your door
07-27-2017, 09:47 PM | #11 |
07-27-2017, 09:48 PM | #12 |
