08-29-2017, 11:48 AM | #1 |
54 GMC fire truck
Ok guy's, I'm in the process of buying a 54 GMC 4500 fire truck cab. I believe they are the same a the 1/2 trucks.
Q1. Is the cab the same as the 100 series cabs? Q2. Is the grill and hood the same as the smaller truck? Q3. What other parts off a 4500 series will work on the smaller trucks? Any help in these areas will be greatly appreciated! |
08-29-2017, 12:26 PM | #2 |
Re: 54 GMC fire truck
Wait until more knowledgeable guys post but I am thinking that hood and fenders are different. The cab may be the same but the hood and fenders are different I am pretty sure.
Here is a link to a thread on the subject. https://www.jalopyjournal.com/forum/...-chevy.743582/ And really, you should be rebuilding it as a fire truck, what fun that would be! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
08-29-2017, 01:15 PM | #3 |
Post Whore
the gmc 4500 is a 1 1/2 ton truck..the cab will be the same for all ad trucks from 1/2-2ton..the front fenders and hood are not...the 4500 front end is longer and wider than a 1/2-1ton truck...I'm not sure about the gmc grill being the same...so in short only the cab will interchange..
08-29-2017, 03:15 PM | #4 |
I'm going to keep the fire truck paint and marking but put it on an 1/2 ton frame. One reason its already blown apart and the other I don't want a 2 ton truck! LOL
08-29-2017, 03:15 PM | #5 | |
08-29-2017, 03:26 PM | #6 |
Post Whore
also be aware that the wheel openings on the 4500 fenders are a good bit larger than a halfton..if your gonna use them...also check out lower50s build ...he used a gmc big truck for his build
08-29-2017, 04:15 PM | #7 |
I've been reading through his thread trying to find out how he used everything! Not sure if I want the bigger front end! I'll use the cab and try and find a 100 series dog house. If the grill is the same I'll use it and what ever else fits a 100 series.
08-29-2017, 04:42 PM | #8 |
Since yu want a smaller truck would a 80-87 1/2 ton K10 work? Front end is definitely wider as i found out.
08-29-2017, 06:39 PM | #9 | |
Hollister Road Co.
2. no 3. nothing. seat maybe. 4. I assume you mean GMC 450 not 4500 |
08-29-2017, 07:47 PM | #10 |
Cab should be the same,
Hood and fenders are different as the guys said earlier. The 400 series grill will be 1-1/2 inch or so taller than the 100 series if they match what happens on Chevrolets. You should be able to use the bars from the 400 in a 100 grill surround though. That is if you want to go to a 100 series nose.
08-31-2017, 10:21 AM | #11 |
Sorry I didn't see this sooner. From what I have found is. The fenders are the same length as small but are wider and taller. They also round up more than small, the hood has more of an arc to the sides to match the fenders and is longer. I am not sure if the grill would fit a small truck. The cabs are the same. I have been trying to get my truck beside a small GMC to compare. Any pictures of what you got?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
08-31-2017, 03:16 PM | #12 |
I will post some soon.
08-31-2017, 05:53 PM | #13 |
Post Whore
lower50s...I thought the big fenders were a few inches longer as well...? are they not?
LCA...really would like to see some pics as well...most big old fire trucks I've seen have a big square hole cut thru the grill to run a pump..is yours that way...if so a grill may be hard to come by for a gmc |
09-01-2017, 09:09 AM | #14 |
Not they are prefect. No holes. I'll get pics.
09-01-2017, 10:34 AM | #15 | |
09-01-2017, 11:27 AM | #16 |
well that didn't work!
09-01-2017, 02:22 PM | #17 |
Post Whore
thanks lower50...I've never done side by side but was always told wider, longer, taller...thanks for clearing it up..
09-01-2017, 02:24 PM | #18 |
Post Whore
LCA...maybe this'll help..http://67-72chevytrucks.com/vboard/s...sting+pictures
