Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-21-2017, 06:08 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Where to locate high quality & correct battery cables?
The terminal in this picture was at the starter on my 71. The cable may have been original, though for whatever it's worth was for a top post battery.
If you ask me, this terminal is the correct way to hook-up to the starter. Does anyone know where to find a high quality cable with this or a similar terminal?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-22-2017, 02:09 AM   #2
71CHEVYSHORTBED402
Re: Where to locate high quality & correct battery cables?
Must be some great cables out there. Perhaps without the terminal? On a side, every starter I've seen on these trucks has a provision for the tab on the terminal.
This one doesn't look bad. I hear they're supposed to be 45", but okay. http://www.classicparts.com/1972-Bat...8g#prettyPhoto[gallery] nofollow/0/
Tony
Old 06-22-2017, 01:05 PM   #3
DieselSJ
The tab is to keep it from rotating and allowing the cable to touch the exhaust manifold. There are a number of places where you can get 90 degree cable lugs but I've never seen any with that tab. I built myself a set of 1ga cables and just used the 90 degree and haven't had any issues. I've got all the stuff to make custom cables, just no time right now to do any. I'm planning to start offering them for sale as soon as I get my shop finished.
These are similar to what I use but I have a supplier that makes heavier ones.
http://terminalsupplyco.com/Store/De...ATDRILL=LUG020
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 06-22-2017, 05:11 PM   #4
SilverMiner
SilverMiner's Avatar
I have bought cables from this company custombatterycables.com in the recent past for my 1980 Suburban, and was very pleased. The positive cable has the 90 degree post almost identical to your picture but without the rotation limiting tab, which I was not aware of before seeing your example. Works fine for me.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 06-22-2017, 08:57 PM   #5
71CHEVYSHORTBED402
Thanks for that and noted. Wholly smokes, they need someone to build a front end for their website. YIKES!
Tony
Old 06-22-2017, 09:05 PM   #6
71CHEVYSHORTBED402
If in business again & think about it, please look me up. I shouldn't need them for a long while. Frame off and still in pull mode.
Tony
Old 06-25-2017, 11:19 AM   #7
DieselSJ
PM sent.
Old 06-27-2017, 12:13 PM   #8
toiletbowl54
I know Mad Electrical offers custom made cables.
toiletbowl54 is offline   Reply With Quote
