05-05-2018, 08:04 AM | #1 |
Plastic gauge or not?
Just picked up my block from the machine shop.
It was washed , honed, and the crankshaft was polished. The machine shop ordered and supplied all my parts.(Lower end) Pistons, pistons rings. rod bearing. main bearing. My question is Do I spent the time to Plastic Gauge it? I would think all is good. Machine shop spec it all all and ordered parts to match |
05-05-2018, 08:35 AM | #2 |
Re: Plastic gauge or not?
the is in the details
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-05-2018, 08:54 AM | #3 |
05-05-2018, 10:49 AM | #4 |
30 mins of time now double check can save u hours later down the road if u have to pull it out
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-05-2018, 01:40 PM | #5 |
It's the only way to know for sure!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-05-2018, 03:58 PM | #6 |
just picked up some.
05-14-2018, 11:54 AM | #7 |
What'd your clearances look like?
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
05-14-2018, 06:19 PM | #8 |
05-17-2018, 08:04 PM | #9 | ||
"I ain't nobody, dork."
I always wash my blocks with mild dishsoap and water and rinse thouroughly. Also spray out all the oil galleries and coolant passages as well. I also use compressed air in all the blind fastener holes in the block as well. Lots of metal particles from the machining process can get everywhere. Then platigauge everything to make certain clearances are good.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-21-2018, 09:05 PM | #10 |
laying low
Yeah, clean it good. And so far as letting the shop measure and order your parts. Ya gotta check after them.
Back in the 70s my bil built up a nice 427 for his little brother's camaro. He bought his parts from our local chevy dealer. Trusted them to get him the RIGHT parts. He put it together and dropped it in the car, got it running good and took it down the street. It spun a rod bearing and ruined the crank. He found one rod bearing in the set didn't match the rest. Wrong size. The parts guy said you should have check them all before putting them in. Tough #$Y^!
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-25-2018, 11:04 AM | #11 |
A machinist friend doesn't check his if he totally trusts the shop doing the crank grind. But that crank shop, "Sheldust" in Pacheco, CA, no longer does cranks.
I got a crank kit from Rock Auto for my 350 and checked it just to make sure. They were all good.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
05-29-2018, 01:01 PM | #12 |
Is this the same engine that the crank would not turn once the rod bolts were tighten down ?
05-29-2018, 06:05 PM | #13 |
06-07-2018, 11:00 PM | #14 |
Trust but verify. The .0015 sounds a little tight to me. IIRC mine was .003 on the mains and .0025 on the rods.
06-09-2018, 08:33 AM | #15 |
It does seem a little tight. Here is a little reading.
http://www.superchevy.com/how-to/eng...learance-info/
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-09-2018, 12:08 PM | #16 |
If this is the engine that would not turn over after you tightened the rod bolts, I would go back thru the process of checking the clearances again since you figured out you installed the wrong piston/rod into the wrong place on the engine....just a thought, its a little bit of time but beats pulling the engine back out of the vehicle later...GOOD LUCK !! maybe you really were "born lucky"
06-17-2018, 12:26 PM | #17 | |
The measurement I gave was off the green tape. Today I matched green with red. The red showed .003 when matched up to the green .0015. |
06-20-2018, 01:09 PM | #18 | |
Here is a decent video on how to use it - https://www.youtube.com/watch?v=q3pHb-qXZc8
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
Thread Tools | |
Display Modes | |
