Old 05-16-2018, 08:05 PM   #1
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Question I Need Water Pump Torque Values?
I'm in need of the 6ea mount bolts and the idle pulley nuts on an all aluminum 5.3L block RPO LO8 2010 Colorado.
Tnkx.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-16-2018, 09:09 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: I Need Water Pump Torque Values?
For the water pump: First pass is 11 ft/lbs. Second pass is 22 ft/lbs.
The 3 bolts for the belt tensioner should be 37 ft/lbs.
95 S_Trucker is offline   Reply With Quote
Old 05-17-2018, 02:07 AM   #3
truckdude239
truckdude239's Avatar
Are you looking for torque specs or are u looking to buy the bolts and nuts?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-17-2018, 08:22 AM   #4
95 S_Trucker
Title says torque values?
If you need the bolds, get them at the dealer, hardware store bolts look out of place.
Old 05-17-2018, 03:18 PM   #5
87 STEPPER
87 STEPPER's Avatar
Thumbs up Re: I Need Water Pump Torque Values?
Thanks 95 S Trucker that's what I was looking for.
In the aviation profession a fastener Torque is known as or referred to as a Value not a Spec.
Are the water pump mount bolts on the LS engines known for going bad?
I've had this truck 4 yr's and it's the original pump and this is the first thing that I've had to replace on it other than plugs n wires.
I don't know if the hardware is good or bad as I am still driving it I plan to do the water pump this weekend. It's leaking out the weep hole after only 267.000 miles.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 05-17-2018, 03:32 PM   #6
truckdude239
Ive never repalced water pump bolts on an ls and i've done abunch of them at work
David fuller
2000 Tahoe 5.3l 378
Old 05-17-2018, 03:43 PM   #7
95 S_Trucker
Youre first sentence says you are in need of 6 bolts and nuts for the idler. It was a little unclear on this side of the screen.
The bolts don't go bad.
Old 05-17-2018, 05:53 PM   #8
87 STEPPER
87 STEPPER's Avatar
Wink Re: I Need Water Pump Torque Values?
Yeah I can see how that looks like I'm looking for the hardware sorry for the confusion.
Thank you both for this info.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 05-17-2018, 07:53 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Just replaced the water pump on my LQ4 in my '06 Silverado. Reused the original bolts... no prob.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
