Old 03-28-2022, 03:26 PM   #1
pwdcougar
pwdcougar's Avatar
97 low pedal empty resivoir
As the title says: 97 K low pedal and the master is almost empty. There is no visible leakage. I'm thinking it's a leaking master.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 03-30-2022, 11:41 AM   #2
sntrym95
sntrym95's Avatar
Re: 97 low pedal empty resivoir
could be leaking in the rear drums. I'd check there and the rear lines inside the driver's side frame rail to see if fluid pooled up in there.
Mike
sntrym95 is offline   Reply With Quote
Old 03-30-2022, 12:18 PM   #3
pwdcougar
pwdcougar's Avatar
I’ll check there next. There wasn’t any brake fluid between the master and the booster yesterday when I separated them.
