Old 05-22-2018, 09:38 AM   #1951
robnolimit
robnolimit's Avatar
Re: Make it handle
Originally Posted by aggie91 View Post
Rob,
OK, After reading thru you post (#1947), I have another approach I would like some advise on for my next build. I have a bunch of parts already just waiting to be used, so here is what I plan to put together. This would work for any '63-'72 truck since the suspensions are the same for those years...
Front:
Recessed the stock cross member up into the frame 1.5"
Porterbuilt Forward Lower arms (2013 versions)
Stock Upper Arms
Air Bags (could go to stock coil springs)
13" C4 Corvette Brakes on 2.5" drop spindles (from way2lo)
Upper Shock Mount relocated
Shocks - Would like to use Ridetech HQ series adjustable shocks, OR? (Don't have shocks yet)
1.25" Porterbuilt sway bar for the forward arms
No Limits Steering Rack Conversion Kit
Rear:
Modify rear rails (like you did with JT) to lower the rear
Air Bags (could go to 2"-4" lower coil springs)
Pan Hard bar - From mount is extended and has multiple holes for setting height, keep it long so that it mounts to Passenger side Trailing Arm at the end, Mount has 3 locations to help set height and keep the bar parallel at ride height.
Sway Bar - Don't have this yet so I am open to suggestions, Price might be a deciding factor.
Brakes: 12" C4 Corvette single piston, with drum in hat parking brake.
At this point, I am planning some sort of 18" or 20" wheel/tire combination, just not sure on tire sizing for the front or rear, any suggestions?
I fully understand that the performance of the suspension with be limited, but at this point so is my driving The truck will mostly be a fun driver that I can daily if I want to, but there will be an Autocross event for fun (Good Guys, local events, etc...) from time to time...
What other low cost changes would you recommend to maximize what I have to work with already? Taller Upper Ball Joints, etc...
Any advise would be great, I have a bunch of parts that I want to use and only spend money (with in reason) on what I don't have on hand to build my next truck.
Karl, this is really similar to the #4 version of the JT (bags on all 4). Our plan with the JT was to see how far we could take a 'stock' based chassis. Looks like your plan has better brakes. While 'vette stuff works great on 'vettes, remember the a C4 weighed in at 3100 wet, with 50/50 balance. The OE 12" brake from a 73-87 has more potential brake torque than the vette parts, but they are heavier. Just FYI. Would be a fun driver.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 05-22-2018, 09:42 AM   #1952
robnolimit
robnolimit's Avatar
Re: Make it handle
Originally Posted by PMDc View Post
Rob,
Thank you for the wealth of information you have unselfishly provided here. Prior to reading this I was thinking I could modify my stock suspension enough to reach my goals but you have a future customer now. For the same money as other stock frame suspension mods on the market, I can get corrected geometry suspension using the Wide Ride IFS and Rear Fat Bar systems from No Limit.
While I'm saving up for this upgrade I have all of the basic knowledge of what can be expected from stock parts and cheap mods. Awesome, awesome thread!
THANK YOU!
-Pat
Thanks Pat. I don't want to step on anyone's toes, or say that "this is the only way", but I also don't want to watch everybody learn the hard way, it's expensive and disappointing. Plan your build, build you plan.
Old 05-23-2018, 03:15 PM   #1953
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Make it handle
So, would the taller upper ball joints give me any benefit? Looking thru my stash of parts, that is one item I will need to purchase. Stock or taller?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-07-2018, 09:35 AM   #1954
robnolimit
robnolimit's Avatar
Re: Make it handle
A taller ball joint will give you a little more camber gain under compression. If you are going to buy new uppers, you may as well get tall ones. Not too much more $$ for the benefit.
Old 06-08-2018, 09:28 AM   #1955
aggie91
aggie91's Avatar
Re: Make it handle
Thanks Rob!
Karl
The LST Challenge:
Old 07-24-2018, 03:42 PM   #1956
jfnar
Re: Make it handle
Here's a simple question that may have already been addressed but I don't have time to read through 79 pgs of posts and the search didn't find anything. I have a 68 swb with coil rear springs. It sits unlevel so I think I need to replace the springs. What's the best replacement coil spring to get the best ride on a stock height truck? No racing or hauling, just driving. Thanks.
jfnar is offline   Reply With Quote
Old 07-25-2018, 10:04 AM   #1957
SCOTI
SCOTI's Avatar
Re: Make it handle
Moog.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-25-2018, 11:34 PM   #1958
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Make it handle
Earlier, when talking about x braces, what about the 60-62 x-frame; would it be enough in its stock form to negate the need for boxing and x bracing?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-04-2018, 01:18 PM   #1959
robnolimit
robnolimit's Avatar
Re: Make it handle
The 60-61 OE SWB is one of the best GM ever made. It simply cost too much $$. Using one of these is a pretty good start, but the cab and core mounts are different 60-62, 63-66, 67-72, so it's not a direct swap.
Old 10-04-2018, 01:22 PM   #1960
robnolimit
robnolimit's Avatar
Re: Make it handle
So my first question is, Is it the front springs, or the rear springs? Park on level ground and then jack the front up until the tires are off the ground. Put jack stands under the front frame at even heights, so that the frame is level side-to-side on the stands. (isolating the rear). then check the rear spring heights. Then reverse the process and check the front spring heights.
Old 10-04-2018, 01:52 PM   #1961
LostMy65
LostMy65's Avatar
Re: Make it handle
Sorry, I should have gave more info.
My 65 is already on a 62 swb frame.
I was considering putting it back on a 63-66 frame, but after reading in these forums, I was wondering if I am further ahead just keeping my 65 on the 62 frame.
Old 11-13-2018, 12:58 PM   #1962
DMiller307
Re: Make it handle
Looking for suggestions on suspension modifications for my 57 dubl-duti. Has a small block 350 and auto overdrive tranny. 104" wheelbase 3/4 ton.
Thanks, Dan
DMiller307 is offline   Reply With Quote
Old 11-14-2018, 10:06 AM   #1963
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks, Dan
We have done these using our Wide-Ride IFS kits. Air or C/O. The rack has to be changed to a Flaming River billit rack so that it can be rotated to point the rack input "up and forward". We only have 5 or 6 lug hubs for these IFS units, no 8 lug.
Old 12-28-2018, 09:45 PM   #1964
GlennL
Re: Make it handle
So how much shorter are you guys going with steering colum on the 67-72 with the No Limit Wide Ride front kit?
I cut 3" off so far and I am thinking another 2 will be needed. Want to push the steering wheel forward a bit while shortening the stickout past the firewall.
GlennL is offline   Reply With Quote
Old 01-06-2019, 05:40 PM   #1965
AustinBelair
Re: Make it handle
Man, you guys are way more advanced than I am. I am working on my 87 short bed and really want to make it handle. My dream would new crossmembers, coilovers front and rear, big sways etc but I will never be able to afford that. One of my daily drivers is a supercharged newer Camaro with a bunch of suspension mods and I love it.
My 87 has CPP tubular uppers with Moog BJ's, completely rebuilt lower arms with 1" Belltech springs and I have a 1-3/8" sway bar that I have not installed yet. All of the other front suspension is brand new. The truck rides great in the front but HORRIBLE in the rear. Like really hard. I know it's an old truck and won't ride like a caddy but this is to the point where I think something is very wrong with the rear leafs or there is some kind of bind.
I've asked other people with squares if I could push down on their truck in the rear and I can move theirs up and down. If you try to push down on mine, it doesn't budge. I hate it.
Should I remove a leaf? Ii put new AC Delco rear "Stock replacement" shocks on the rear and it did not change it. I have Eibach 2" drop shackles on it now and they did not alter the ride at all.
I would love the Ridetech rear mono-leaf springs but at $800+ for them, I can't swing that.
Are there any other things I can do? Any donor trucks with the same leafs that I can make a "Bastard pack" out of that will ride better? A good 4 link rear coilover kit that doesn't require a frame c-notch?
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 01-06-2019, 10:46 PM   #1966
Wikid61
Wikid61's Avatar
Re: Make it handle
Try to stick with a reasonable aproach, and you'l get good results. If you start with the leafs, lets say that the top spring with the eye is #1, and the count down from there to the shortest #6. Keep 1,2, & 3. pull #4, keep #5, pull #6. Use a hand gringer/sander to round off and radius the ends of the springs. Get some teflon liner to put between the leafs (speedway, Eaton, ..) and reassemble. Call Helwig and get a 1" rear sway bar. From RideTech, use pt # ARK2004, with a shrader fill kit. ~Thats Rob's quote from page 18 of this thread. When you tighten the bolts that run through the eyelets of the springs, the vehicle's tires need to be on the ground to prevent preloading/bind.
Wikid61 is online now   Reply With Quote
Old 01-07-2019, 02:15 PM   #1967
SCOTI
SCOTI's Avatar
Re: Make it handle
Look into Chris Alston's Chassis-Works for the original bolt-on KP Compnents 4-bar set-up. That gets you the bracketry for bolting in the 4-bar. Then find some weld-on coil-over brackets for installing coil-overs. I would go w/Ridetech for the C/O's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2019, 02:45 PM   #1968
robnolimit
robnolimit's Avatar
Re: Make it handle
Take a look at out 73-87 FatBar rr suspension kits. - you do have to weld brackets to the axle.
***My 87 has CPP tubular uppers with Moog BJ's, completely rebuilt lower arms with 1" Belltech springs and I have a 1-3/8" sway bar that I have not installed yet. All of the other front suspension is brand new. The truck rides great in the front but HORRIBLE in the rear. Like really hard. I know it's an old truck and won't ride like a caddy but this is to the point where I think something is very wrong with the rear leafs or there is some kind of bind.***
Probably not in a bind, just how it was made. a 1/2 ton was expected to carry 1000 lbs of cargo, + 150 lbs of tools/support gear (GM spec) AND three (yes three) adults (so another 600 lbs. You could est that 1/2 of the weight of people and tools would be carried on the front suspension (so about 375) but then they built the rear to carry another 1375 ABOVE the empty truck. (not counting the overloads, or HD trailer springs). You need to reduce the spring rate if you want it to ride good. you can try pulling a leaf or two. One of the longer ones and a shorter one. a little wrench time, but no $$. (well, probably a new center bolt) - you can use an allen head cap screw.
Old 02-24-2019, 09:14 AM   #1969
Andyking1203
Re: Make it handle
I'm building a 68 c10 swb, I'm thinking I wanna go coil o era front and rear (no limit setups for both ends), what's the advantage of spending this kinda money vs semi stock suspension ( itll be lowered, tubular a arms and tubular trailing arms)? They're is no road course racen up here in the north east... thanks
Andyking1203 is offline   Reply With Quote
Old 02-25-2019, 10:21 AM   #1970
robnolimit
robnolimit's Avatar
Re: Make it handle
This is a great question, and we hear this a lot. There are a few things to consider, and this will help make the best choice for you. Here are some comparisons that I put together this morning.
No Limit Chassis Pack has both front and rear suspensions, motor mounts, trans mount and a P/B kit for your truck. Price is $5195. This will net a 5/7 drop. Using Ridetech or Viking coil-overs. Keep in mind this includes new 12" front brakes, a power rack and pinion steering and front sway bar. Some welding is required for the rear suspension install. (if you choose a 4-bar) no welding with the Trailing arm package. There is a 3" gain in front ground clearance at the bottom of the crossmember and the total IFS swap cuts 215 lbs. The motor will go up 1" (for rack and pinion clearance) so the exhast may need to be modified.
From one popular manufacturer I was able to piece together a front and rear suspension package with coil-overs, drop spindles, dick brakes and a front sway bar. $4636 These parts bolt directly to the OE mounts on the truck. they advertise this as a 4/6 drop. No steering upgrade. This company has mixed reviews. Stock mounts means stock geometry so the performance improvements are minimal - but, the new A-arms would have new bushings and ball joints which would tighten up the truck compared to 50 yr old parts.
Another site had a package for $5725. This is for front suspension (Drop spindles, A-Arms and coil-overs and mounts) and a complete rear trailing arm set up with coil-overs. No brakes in front and no steering upgrades. This company is well known and has a reputation for quality USA made parts. 100% bolt-on install. Again, with all OE mounting points, the suspension geometry is very close to stock (except lowered) the crossmember clearance is the same, as is the motor placement.
One advantage (for some) of the 'bolt on upgrade' kits is that they can be purchased one piece at a time, so you can step in a little at a time. Where as with a total front or rear suspension upgrade, it all has to be changed at one shot. (more cash up front)
**** I discuss this with a lot of people all of the time. The one thing that most of us forget is how old these trucks really are. The geometry of a 67-72 suspension is really the same as a 60-62 (I know, I know, not the same, but, the suspension pivit points are identical, and so is the spindle geometry). These were first for sale in mid 1959. 8 months of pre-production, 9 months testing, 1 yr tooling, 1 yr engineering, and 1 yr design puts the technology date of these somewhere in 1955. Yes, the suspension geometry on a 67-72 chey truck was put on paper in 1955. So, as far as the tech goes, your C10 is from the fifties. Worse yet, this geometry design stayed until 1988. So, the last squarebody in 1987 had the same basic geometry (yes, updated with rubber bushings and disk brakes, but the same geometry) as the 1960, designed in 1955. So, in reality, how good do you really think bolt on parts can improve this? And, how far do you want to go? You don't need to go road racing to want a nice driving truck. Food for thought. Thanks ****
Old 02-25-2019, 10:32 AM   #1971
Andyking1203
Re: Make it handle
Thanks for the response rob!! So what I'm getting from this, is that coil overs front and rear (again no limit setups, most likely the 4 bar and the ifs system). The kit I'm looking at on your site came out a little more then you mentioned, do to ls mounts and what not, which is no big deal. Does this also include rear brakes? I didn't see any options.
Old 03-05-2019, 09:22 AM   #1972
67_ShortFleet
67_ShortFleet's Avatar
Re: Make it handle
Should my track bar mount be here or below the lowering block?
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 03-05-2019, 10:02 AM   #1973
robnolimit
robnolimit's Avatar
Re: Make it handle
With blocks you have some choices. Above or below the block, also, the U-mount can go above (as you have it) or below the plate. The goal is to try to get it level at ride height. (with all of the weight on the suspension)
Old 03-05-2019, 10:38 AM   #1974
67_ShortFleet
Re: Make it handle
Thanks Rob
Matt
HAPPILY DIVORCED!
Old 03-20-2019, 04:06 PM   #1975
Chevy Punk
Re: Make it handle
Hi Rob, thank you for this mass of info and for the fantastic parts! Do you make a kit for a frame mounted master cylinder for 72 c10? I saw it in one of your chassis videos and it looks like the exact setup I want.
Chevy Punk is offline   Reply With Quote
