Old 07-02-2018, 10:15 AM   #1
Sadlerracing529
Frame patch
I tried searching and couldn't find anything on my exact question.
I have a 1963 c10 fleetside long bed and the frame directly above the factory rear coils is rusted through and cracked on only the bottom lip of the frame. In the future I plan to drop in a full rear frame/suspension kit, something like the kp components, or no limit engineering kit. But for now would it be safe to weld in a brace, and would a c notch kit extend far enough forward to help support this and make this truck safe to drive?
The reason I ask is the truck is road worthy right now other than this frame crack, and I would like to drive this truck here and there until I start the actual restoration and mods in a couple years.
Sadlerracing529 is offline   Reply With Quote
Old 07-02-2018, 06:17 PM   #2
Lil Loafer
Re: Frame patch
I would think that you could weld the crack and weld a plate over the rusted part as a temporary fix until you get a new frame as long as you are not hauling a lot of weight.
Lil Loafer is offline   Reply With Quote
Old 07-02-2018, 06:42 PM   #3
Sadlerracing529
Re: Frame patch
No hauling with this truck. It will be a full restoration slowly. Mainly waiting to start the big stuff until I move out of the house I'm currently at. This truck was my grandpas daily driver up until a year ago. It needs some love
Old 07-02-2018, 08:13 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Frame patch
Post some pics.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-02-2018, 08:22 PM   #5
raidmagic
raidmagic's Avatar
Re: Frame patch
I've got a long bed I'm cutting up, you pay the freight and I'll cut the section of frame you need to patch it.
raidmagic is offline   Reply With Quote
Old 07-02-2018, 11:40 PM   #6
Captainfab
60-66 Nut
Re: Frame patch
Depending on how bad the rust is, you could likely get away with plating just the bottom flange. Just be sure to clean off all the rust down to good metal so that you get a decent weld. And don't weld across the flange, just lengthwise.
Old 07-03-2018, 06:28 AM   #7
Sadlerracing529
Re: Frame patch
Originally Posted by LostMy65 View Post
Post some pics.
I will get some pics up after work today
Old 07-03-2018, 06:29 AM   #8
Sadlerracing529
Re: Frame patch
Why weld only lengthwise and not across? Risk of distortion?
Old 07-03-2018, 06:31 AM   #9
Sadlerracing529
Re: Frame patch
I really appreciate your offer, I think just a small patch will do the trick, but I will keep your offer in mind if I need to get more serious with it
Old 07-03-2018, 08:37 AM   #10
69 C10 LWB
Re: Frame patch
Welding across the frame creates a spot where the frame can crack. The frames are designed to flex a little and the weld will not flex like the frame but will crack instead.
69 C10 LWB is offline   Reply With Quote
Old 07-03-2018, 11:39 PM   #11
Captainfab
60-66 Nut
Re: Frame patch
Just as 69 C10 LWB said, the frame can crack where you weld across.
Old 07-04-2018, 10:41 AM   #12
Sadlerracing529
Re: Frame patch
The top picture is the passenger side frame rail, bottom is the drivers side
Old 07-04-2018, 12:20 PM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Frame patch
What are those strap looking things on the rear end?
Old 07-04-2018, 12:22 PM   #14
Sadlerracing529
Re: Frame patch
It has a weird half leaf spring on each side...some sort of vintage helper spring or something
Old 07-04-2018, 12:29 PM   #15
Sadlerracing529
Re: Frame patch
Here is a pic of the weird spring set up
Old 07-04-2018, 11:51 PM   #16
Captainfab
60-66 Nut
Re: Frame patch
It looks like you're going to need to replace the lower brace of the crossmember as well.
Old 07-05-2018, 02:48 PM   #17
Sadlerracing529
Re: Frame patch
The more I dig in to this truck, the more work it needs just to make it safe to drive. I think this project is going on the back burner until I get out of the house im currently in and have the space and time to just do it once, and do it right. Thanks for all the help on this one guys. Will just focus on building the motor for the truck for now since I have the space to do that. I will start an actual build thread for the truck once I tear into it
Old 07-05-2018, 07:35 PM   #18
Clyde65
Clyde65's Avatar
Re: Frame patch
My suggestion is to see if you can find a long bed frame on CL or through the parts page here. I have seen plenty on the Dallas CL as well as Arizona and NM. It would be cheaper to have a trucker bring it to you than all the work your gonna need to “make it safe”
Good luck!!
https://dallas.craigslist.org/dal/pt...614573770.html
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
