Old 11-29-2017, 01:47 PM   #26
daddyjeep
daddyjeep's Avatar
Re: 1991 ccsb duramax
Good deal. The chop turned out nice and clean.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 11-30-2017, 04:33 PM   #27
freemoto_xxx
Bedsides almost ready for paint
freemoto_xxx is offline   Reply With Quote
Old 12-03-2017, 03:52 AM   #28
freemoto_xxx
Under coated the frame and buttoned up the front end
Old 12-12-2017, 01:07 AM   #29
freemoto_xxx
Built my own exhaust with some 3" mandreals
Old 12-14-2017, 02:50 AM   #30
freemoto_xxx
More goodies for this weekend
Old 12-18-2017, 07:00 PM   #31
freemoto_xxx
Lift kit installed! Still need to install crossover steering tho
Old 12-19-2017, 01:11 PM   #32
daddyjeep
daddyjeep's Avatar
What did you go with for the lift? 4" or 6"?
04 1500 crew cab
Old 12-19-2017, 03:58 PM   #33
freemoto_xxx
4" skyjacker
Old 12-19-2017, 07:59 PM   #34
Feel the 'Pane
Awesome build!
What are you going to put behind the Dmax? (Man/auto)
What are your plans for the finished product? A service truck or ???
FtP
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver
77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10
Flatbed
82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56
Flatbed, 6"Rancho, Alcoa's
Feel the 'Pane is offline   Reply With Quote
Old 12-20-2017, 01:12 PM   #35
daddyjeep
daddyjeep's Avatar
Originally Posted by freemoto_xxx View Post
4" skyjacker
It looks pretty tall for 4", but I'm sure it will settle some.
04 1500 crew cab
Old 12-21-2017, 01:32 AM   #36
Maxxd07
Maxxd07's Avatar
Count me in on this build. Have wanted to do one with a dmax myself.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 12-31-2017, 03:19 AM   #37
freemoto_xxx
Starting to install the crossover steering tonight!
Old 01-01-2018, 02:15 AM   #38
freemoto_xxx
Cross over steering done
Old 01-01-2018, 09:33 AM   #39
sweetk30
sweetk30's Avatar
crossover tend to be installed in the front hole . the rear hole is for high steer use .
watch out for them sh!tty cast aluminum shims sky jacker uses . i have had a few sets break out and fall out after just a few months . and 4" lift i would just remove them my self . helps keep the caster were it should be as dana 60 axles are a bit fussy on caster and death wobble showing up if its wrong .
otherwise looking good .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-01-2018, 11:15 PM   #40
freemoto_xxx
Oh dang your right! Haha wrong hole! I used 3 4 degree steel shims
Old 01-22-2018, 01:33 AM   #41
freemoto_xxx
Bed lines up perfect
Old 01-23-2018, 05:05 AM   #42
Nick_R_23
Nick_R_23's Avatar
Nice work! What part of Alaska are you in?
Old 01-25-2018, 09:40 AM   #43
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Following along. Looks great so far!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-26-2018, 04:24 PM   #44
shootracing22
Subscribed.
Its looking good!! I have a similar Cummins swapped truck.
2006 GMC X-cab Z71 5.3LS
1994 GMC 1500 LWB 2wd
1989 Chevy Crew v3500 4x4 12 valve Cummins swap
http://www.4btswaps.com/forum/showth...-for-feed-back
shootracing22 is offline   Reply With Quote
Old 01-26-2018, 05:22 PM   #45
truckfan
truckfan's Avatar
lurk
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 02-11-2018, 01:36 AM   #46
freemoto_xxx
Time to clean up the front end! Repainted the core support and new led headlights and marker lights
Old 02-11-2018, 02:15 AM   #47
Indyfab
Indyfab's Avatar
Where did you get the led headlights?
Indyfab is offline   Reply With Quote
Old 02-12-2018, 03:10 AM   #48
freemoto_xxx
Lmc
Old 02-12-2018, 03:12 AM   #49
freemoto_xxx
New led headlights look so much nicer
Old 02-12-2018, 09:19 AM   #50
sweetk30
sweetk30's Avatar
the problem with most led headlight upgrades is SNOW / ICE driving .
there is no heater grid to melt them off . all the heat is out the back side not the front were you need it .
i just did a full led upgrade on my work truck that takes 4x6 4 headlight system . all i can say is WOW worth every penny i spent on good units . . . j.w.speaker with heater grid .
sad part is not offered in this tiny size for 89-91 quad light style tho .
