05-14-2018, 12:28 PM | #1 |
70+ ( Old Skool Club )
Front Marker Lights went out..
Ths is one of those electrical things that drive you nuts. Maybe its happened to someone else so I'm reaching here. My front marker lights all of a sudden stopped working. My headlights, front signal lights and rear marker lights work normally. I checked the connector on each side with a test light and there is power to them with test light grounded to the battery. I even tried new bulbs but no change. The wiring is original and hasn't been hacked. Something obviously happened to the ground wire but I have no clue what. Any ideas and suggestions will be much appreciated.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-17-2018, 02:49 PM | #2 |
Re: Front Marker Lights went out..
Do get a voltage reading when the ground clip is attached to the hood?
05-17-2018, 03:38 PM | #3 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=763813
