Old 03-30-2013, 01:33 AM   #1
shipma3
reverse makes a loud bang
is it fairly normal for the reverse gear in a th350 to make a loud bang when it goes into gear? my stepdad's k20 did the same thing as my k10 but he did not have any problems with the tranny up til he sold it
shipma3 is offline   Reply With Quote
Old 03-30-2013, 03:11 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: reverse makes a loud bang
Find out if the bang is from the diff or the trans
My freinds banged when he shifted into gear. More so in reverse. The spider gears and center chart in the diff were so warn they were about to let go.
You can tell if you have a buddy look under and watch the driveshaft move a hole bunch when you go from D to R plus you hear it.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-25-2013, 02:23 AM   #3
shipma3
sorry for bumping a old post but ya it was the rear diff after replacing it it does not shift near as hard into reverse
Old 10-25-2013, 07:34 AM   #4
riz
Check your u-joints in the rear end.... sloppy u-joints can make a nasty banging when going into reverse.
RIZ
riz is offline   Reply With Quote
Old 10-25-2013, 11:08 PM   #5
wilkin250r
wilkin250r's Avatar
Yeppers, differential will do it. My truck is full-time 4wd, and it's my front diff that goes "clunk" when shifting into reverse.
I haven't torn into mine yet. Of all the things that could possibly be wrong in there (worn/broken teeth on the ring or pinion, bad spider gears, ect ect) is there any culprit that is more likely than others?
It's a D44 front, and it's DEFINITELY clunking in the front diff. It's not a U-joint.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
th350, tranny, transmissions
