Old 01-09-2018, 09:57 PM   #1
batman09
Truck wanders when driving
Need a little advice...my newly acquired 1970 c10 wanders left to right when driving....any thoughts on what it could be? Has cpp upper a arms..stock lowers with coil overs
Has agr steering box(new)
https://www.summitracing.com/parts/a...del/c10-pickup
Steering box or alignment is what I was thinking....alignment looks good to the naked eye
Thanks for the help!!
1970 c10 ls2/4l60e
1967 Nova---LS3/4L70e
batman09 is offline   Reply With Quote
Old 01-10-2018, 07:56 AM   #2
PGSigns
PGSigns's Avatar
Re: Truck wanders when driving
First would be to ensure everything is tight and looks like no worn parts or bushings. I would get it aligned and see what you have. It may look OK but if it has little or no caster it will not track well. I like 3 degrees of caster.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-10-2018, 02:29 PM   #3
bs46488
Subbed as I have similar problems. I'm pretty sure my issue is bumbsteer, followed by a way off alignment.
Can you post pics of your suspension setup? That would help.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 01-11-2018, 11:10 PM   #4
batman09
Sorry I don't have a lift
1970 c10 ls2/4l60e
Old 01-15-2018, 05:03 PM   #5
Bigd18
Toe in can cause a vehicle to wander as well as bumpsteer. Does it happen on rough roads with bumps or anytime, including smooth roads? If the road is flat and smooth then I would go with toe in first.
Bigd18 is offline   Reply With Quote
Old 01-27-2018, 05:09 PM   #6
batman09
It happens all the time
1970 c10 ls2/4l60e
Old 01-28-2018, 07:25 PM   #7
PGSigns
PGSigns's Avatar
First thing to do is to check it over for any worn parts and get that fixed first. Then a good alignment.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-30-2018, 09:47 PM   #8
batman09
Jimmy
Everything tight/new... just had alignment done.. all good ...still twitchy..crazy bumpsterr and wanders... think it's the agr steering box
1970 c10 ls2/4l60e
Old 01-31-2018, 07:31 AM   #9
PGSigns
PGSigns's Avatar
How much caster did you end up with and did they do a bump steer check?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-31-2018, 07:33 AM   #10
batman09
Jimmy
3.6 positive...never heard of a bump steer check? What is that?
1970 c10 ls2/4l60e
Old 02-02-2018, 01:54 AM   #11
midniteblues
midniteblues's Avatar
This issue comes up often on the main page alot.
Check your inner tie rods if the studs are pointing to the rear of the truck then you have a center link thats been flipped backwards.
Its a very easy mistake to make, goes unnoticed by many(even the alignment shops) and will cause exactly the issues your describing.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
71 c20 4x4 400/4 spd....01 sporty 883.
2000 s10 zr2 little blue truck that never gets stuck.
09 hhr. Momma's wagon. 06 chevy cobalt,blue light special
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-02-2018, 02:04 AM   #12
ryanv70c10
Bruce, post a picture of your centerlink. It may be on backwards. If backward it causes what you're describing.
ryanv70c10 is offline   Reply With Quote
Old 02-02-2018, 07:53 AM   #13
PGSigns
PGSigns's Avatar
What we do on the alignment rack on the drag cars to check bump steer is raise the front slowly and see how bad the tow changes as it goes up. This was used to see if we needed to limit the travel and if so about where. That way when the front went up in the air the wheels would be at least close to straight. If the tie rods are running up hill at ride height on a lowered truck you can get bump steer as the front goes up and the toe begins to point out. So a check on the rack if there is a concern is to raise the front a few inches and see what the change is.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-02-2018, 09:06 AM   #14
batman09
Old 02-02-2018, 11:22 PM   #15
Boog
Senior moment
Boog's Avatar
right side up.
Boog
69 Chevy stepside, 358/T350, 4.10 posi, 4.5/4 drop, rallys, poboy driver
09 Yukon SLT 4wd, 06 GMC crewcab Z71 5.3, 4.10
All GM..'nuff said,
Member of Jr Nation 88
Copyright ©2000 - 2019, vBulletin Solutions Inc.
