Old 02-22-2018, 09:59 PM   #1
GMDad
GMDad's Avatar
Dome lamp don't turn off
The dome lamp and under dash lamps are staying on and killing the battery..
I pulled both doorjamb switches but the wiring terminals won't fit thru the threaded hole for the switch so I can't check the wires... headlamp switch is other option. Is there an easier way to check this out ?
GMDad is offline   Reply With Quote
Old 02-22-2018, 10:08 PM   #2
kwmech
Re: Dome lamp don't turn off
Bare white wire to ground somewhere or a bad Headlamp Switch. How about the wire going along the sill plate.
Old 02-23-2018, 10:25 AM   #3
TKCR
TKCR's Avatar
I would venture to say, it is the door switches. They probably need replaced, if they never have been. It is a pain to do. My wiring was laying loose between the panels, behind the kickpanels. They had rusted and broke off at the terminals. I just happened to find them when I was redoing the dash. I pull them out from behind kick panels and wondered what they were supposed to go to. After figuring out that they were the door switch wires, I took the door switches out and saw that the were rusted on the backside where the terminals once were.
Got new switches and I fished for my wires thru the door switch hole. And here's the hard part, especially on the left side, you can only pull 1 terminal out through the hole, at a time. If I remember right, the passenger side only has 1 wire.
Old 02-23-2018, 01:23 PM   #4
GMDad
GMDad's Avatar
I played around for about 5 mins but managed to get the switch with wires thru the hole on the drivers side.
Had a new single contact switch I put in passenger side.. nope
took double switch from passenger side and put on drivers side...nope
changed headlamp switch...nope
pulled up sill plates and wiring looks good all along there...
Cant think of anywhere else unless I order a couple new switches an try them ??
Old 02-23-2018, 02:22 PM   #5
blindbug
There's probably a ground short somewhere in the wire between the door switch and the dome light. Can you take a 12v test light and connect one side of the light directly to the battery via long wire, and then connect the other side of the test light to the wire that comes from your door switch. If the light lights up, then you have a ground somewhere between the door switch and your dome light.
If you want to rule out the headlight switch, then connect the other side of the 12v test light to the terminal that connects your door switch to the headlight switch. There's diagrams around this website which detail which particular port on the terminal corresponds to where.
blindbug is offline   Reply With Quote
Old 02-23-2018, 03:45 PM   #6
GMDad
GMDad's Avatar
I didn't think the door switch was hooked to the headlamp switch? Doesn't the door switch just supply the ground and as you were saying could be a short between door switch and lamp. The courtesy lamp also stays on.
Old 02-23-2018, 04:35 PM   #7
mongocanfly
mongocanfly's Avatar
yeah...all the door switch does is makes the ground side of the light circuirt...its either the switch or a bare ground wire somewhere..if you had the door switch out and not touching metal and the lights still on,,then its somewhere else...most probably wiring..but the headlight switch does the same thing when you turn it to turn on interior lights..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-23-2018, 04:36 PM   #8
95 S_Trucker
95 S_Trucker's Avatar
If you spin the headlight switch clockwise until it clicks, the dome lights will come on, even when the doors are shut.
Make sure the switch wasn't turned.
95 S_Trucker is offline   Reply With Quote
Old 02-23-2018, 04:58 PM   #9
TKCR
TKCR's Avatar
I thought of that too later, but you already suggested that
Old 02-23-2018, 10:44 PM   #10
GMDad
GMDad's Avatar
I rotated the knob clockwise and when it clicked the dome lamp got marginally brighter
I borrowed a continuity meter to check each of the individual wires to see if there is a break in any of them. Tomorrow's job.
Old 02-23-2018, 11:00 PM   #11
mongocanfly
you can use that meter to check and see if your ground wires grounded as well...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-24-2018, 10:38 AM   #12
stanski
Just a WAG, but could either the dome or courtesy light be continuously grounded through the light housing mounting? If you unscrew both of those and let them hang the lights should work properly. If you touch either to ground and they stay on, that could be the problem? Had same issue when I installed underdash light on my 58 then realized the housing could not be screwed directly to metal it needed a plastic insulator.
stanski is offline   Reply With Quote
Old 02-24-2018, 11:17 AM   #13
blindbug
The fact that when turning your knob clockwise and when it clicked the dome lamp got marginally brighter should be a tell that the headlight knob isn't the issue. If the dome light is getting brighter, then that should mean that when it clicks, it's getting a proper ground and thus causing the light to be brighter.
If you have a multimeter, check continuity between the wire that's attaching to your dome light, at the dome light, to a ground location. It's got to be the wire getting a ground when it shouldn't be.
Old 02-24-2018, 01:21 PM   #14
GMDad
GMDad's Avatar
Another perplexing morning. I checked the white wire from passenger switch to courtesy lamp in middle of dash...no breaks
Checked from lamp to drivers switch and no breaks
Checked from drivers switch to the dome lamp bulb connector...no breaks. I have taken the dome lamp housing out as when this started I didn't see the light has stayed on during the day but got hot enough to melt housing (and it was a LED bulb) so now just have orange and a white wire hanging from headliner. So I unscrewed both sides switches and left the wires connected and let the switches hang free in the air. Courtesy lamp still on. Only thing left was to pull the headlight switch out and still courtesy lamp is on... the tail lamp and courtesy lamp are on the same fuse. Could I have a problem in tail light area ?
I am a novice at chasing wiring so buddy coming over after lunch. Says he'll have it fixed in 5 mins... hope he's correct as I am running out of ideas
Another quick question... the courtesy lamp has 3 white wires running from it. One to drivers switch, one to passenger switch but can't figure out where the 3rd one goes. It could be my problem as it is joined in the same terminal as drivers switch white wire ?
Old 02-24-2018, 02:22 PM   #15
hatzie
Moderator
hatzie's Avatar
What year is your truck?
It makes a difference in how the ground is sourced through the dome/courtesy circuit.
The door jamb switches ground through the switch to the sheet metal where they pierce the body. The switch closes the circuit between the wire terminal and the switch body when the door opens.
The headlamp switch grounds to the dash frame. This ground is closed to the dome wiring when the plunger is rotated until it clicks.
On some years there's an additional tan ground wire between the ignition switch and the LH door jamb switch making two connections on the LH switch.
There really aren't that many ground wires. Isolate them at both ends and then test continuity to a chassis ground.
Pulling the jamb switches out of the jamb and the headlamp switch out of the dash, or just unplugging it, where they can't touch metal should effectively isolate them.
If you stop getting continuity re-install each switch and re-test. Obviously, the doors MUST be closed or the jamb switches will make contact.
If you're still getting continuity to ground unplug the courtesy lamp and re-check. If your ground goes away carefully use plastic isolation washers to mount the courtesy lamp.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-24-2018, 02:44 PM   #16
GMDad
GMDad's Avatar
It is a 1986 C10. Funny thing it had plastic washers under the head of the door switches on both sides. Both sides were double contact and had a rubber sleeve on the plunger end so I am presuming factory switches.
The courtesy lamp is a plastic housing with a single screw mounting it.
I have printed off your schematics for the cab wiring and the white wire from courtesy lamp shows going to "156" but I haven't been able to figure out what that is... thanks
Old 02-24-2018, 04:13 PM   #17
hatzie
Moderator
hatzie's Avatar
156 is the circuit number so you can follow the circuit 156 wires through the diagrams... across splits in pages and past tangles of other wires on the diagram etc. GM took it to an extreme in 1987 eliminating the single wires you can trace making it very difficult to read the 1987 wiring diagrams.
The reason to show the circuit number in plug cavities is to show the position of that wire in that connector.
Old 02-24-2018, 06:06 PM   #18
GMDad
GMDad's Avatar
And my drivers switch does have a tan and a white wire on it so the white goes to the dome lamp?
Old 02-25-2018, 03:34 AM   #19
Pontiac1976
Pontiac1976's Avatar
Just thought you might check the rear dome light wiring to the left seat post some time the wire short there. It should un plug @ the post and run up the roof to the dome.
should be onrange wire and white wire.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-25-2018, 09:00 AM   #20
Unplug the dome light harness from under the dash. See if trouble goes away. This will help you to isolate which section the ground is coming from.
Old 02-25-2018, 07:33 PM   #21
GMDad
GMDad's Avatar
After more than 4 hours pulling the truck apart and tracing wires the problem is the cargo lamp socket where the wires connect. The cargo lamp harness goes along the inner roof and down the back post and in behind the drivers side rear speaker is a connector that goes from the orange and white wires from door jamb switch and fuse block and is connected to 2 double terminals. A larger white (ground for cargo) and a smaller white (ground for dome lamp) on one terminal and the second terminal has the larger orange (power for cargo) and a smaller orange (power for dome lamp). Ground back fed from cargo lamp socket thus putting the dome lamp on. Now to put it all back together but not today.
Has anybody ordered the cargo lamp harness from LMC. Its $29.95 just curious if socket is on it. Looks like it in the catalog
Old 02-25-2018, 07:44 PM   #22
mongocanfly
when I redid my truck I wired my cargo light separate from my interior light...I didn't like having my interiors on for the cargo to work..just a idea
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-25-2018, 07:53 PM   #23
TKCR
TKCR's Avatar
I know I replaced my harness, it was a pain in the a$$ too. I believe the socket was on there, if I remember correctly. I replaced the cargo lamp and dome light housing, at the same time. Put led bulbs in them, so they don't get so hot when they are on.
It would be a good time to add more light under the dash since you been tearing into all the wiring. I added this kit from LMC. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=204
It added 2 more lights to the one under the dash and added LED's in it too.
Old 02-25-2018, 09:18 PM   #24
akart
I had that problem w/some other EL issues too. It was a fuse.
So, might want to check that.
akart is offline   Reply With Quote
Old 02-25-2018, 09:56 PM   #25
TKCR
TKCR's Avatar
He found the issue, it was a bad socket in the cargo lamp
