Old 07-27-2017, 01:53 PM   #1
Axlereid
Disc brake clearance question
Hey guys
Installed the CPP front disc brake kit on my 66 C-10 and the calipers are now causing clearance issue with the wheels.
Any recommendations to fix this and still keep the stock steel wheel look?
Thanks as always
Axlereid is offline   Reply With Quote
Old 07-27-2017, 03:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc brake clearance question
Originally Posted by Axlereid View Post
Hey guys
Thanks as always
I assume you are running 6-lug disc brakes up front?
Two choices:
1) Run a spacer to move the stock wheels out.
2) Use 71-87 4x4 steel wheels.
These have 4-nubs for the hubcap vs the 3-nubs that yours have.
But they are getting harder to find every day.
4x4 Trucks, blazers and suburbans all had them.
Keith
Convert to disc brakes.
Old 07-27-2017, 04:53 PM   #3
forestb
forestb's Avatar
are they modular spindles or the regular ones?
forestb is offline   Reply With Quote
Old 07-27-2017, 10:36 PM   #4
rvrfoot
Hey guys
Thanks as always
I just did the same thing.If you have stock wheels thay will rub.Do you have pictures?
rvrfoot is offline   Reply With Quote
Old 07-27-2017, 11:31 PM   #5
Captainfab
60-66 Nut
The stock 15" wheels for these trucks are not disc brake compatible.
Old 08-01-2017, 06:32 PM   #6
statenine
statenine's Avatar
this interests me, because I recently installed the regular CPP 2.5" drop spindles, and my stock 15" wheels (3 nub) clear the calipers....just barely but they clear. Is this unheard of?
statenine is offline   Reply With Quote
Old 08-01-2017, 07:54 PM   #7
jocko
jocko's Avatar
It's not UNHEARD of that they don't rub, but I'd say you're pretty lucky. Generally speaking, if you want "stock" steelies and want to stay 6 lug, you need to do what Keith mentions above - 71 and newer K5/K10 wheels will do the trick for your truck, assuming a stock-type single piston caliper. Bigger calipers, not sure. These wheels generally have 4 nubs as a quick ID feature - but, more importantly, they have clearance on the inside of the rime where the caliper resides.
Old 08-10-2017, 03:33 PM   #8
Axlereid
Thanks for all of the answers.
Ended up going with Wheel Vintiques steel and they work great.
Have a great day!
