06-05-2017, 10:40 AM | #1 |
C10 Truck Trailing Arm Anti Squat Bracket Kit
Who else makes these beside POL and Hotchkiss? I'm trying to correct an pinion angle problem that is causing me a vibration and am checking out my options. TIA
https://www.performanceonline.com/19...t-Bracket-Kit/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-05-2017, 12:19 PM | #2 |
Re: C10 Truck Trailing Arm Anti Squat Bracket Kit
I've seen a lot of people flip the bracket. I think Super73 made his own. Any reason you don't shim the rear or weld on new perches?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-05-2017, 12:51 PM | #3 |
I'm using PB dropped arms. The truck is built and running and I was trying to keep it simple. I may just flip the bracket.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-05-2017 at 03:52 PM. |
06-05-2017, 09:44 PM | #4 |
I've thought for a long time if i needed to do this i would weld additional metal plates predrilled and weld them to the top, because i hate to drill out rivets. My grandpa worked on the railroad and fixed steam locomotives and said" nothing beats a rivet, fills misaligned holes, can't unthread, vibration resistant etc. if it holds a skyscraper together it's good enough for me".
06-06-2017, 06:48 AM | #5 |
I use shims to set the angle. Quick and easy. These are from speedway but others also carry them. http://www.speedwaymotors.com/Rear-A...up,294450.html
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-06-2017, 08:11 AM | #6 | ||
Certainly one way to do it, . And agree on the rivits, . Quote:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-06-2017 at 10:07 AM. |
06-08-2017, 08:57 AM | #7 |
Does anyone see a problem with going with a 6 degree shim?
06-08-2017, 11:26 AM | #8 |
motor exploder
FWIW, I'm running a 6* shim on my '69 with Hotchkis 6" rear drop springs & 1.5" block. No issues so far.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
